Hp dv6620ev bios - -too long file please help
  • prospa
    • Sep 2013
    • 21
    • greece
    I HAVE EZP2010 BIOS PROGRAMMER
    I TOOK FROM HP DV6620EV MOTHERBOARD BIOS CHIP AND READ TO PROGRAMMER.
    I TOOK A FILE 1024 KB SIZE. I WANT TO REPROGRAM CHIP BUT NEW BIOS FROM HP SUPPORT HAS 1074KB AND WHEN I TRY TO PROGRAMMING CHIP GET ERROR "FILE IS TOO LONG" FOR THIS CHIP.
    PLEASE HELP HOW CAN I FIX NEW FILE SO I CAN REPROGRAM BIOS.
    HERE IS ORIGINAL FILE FROM MB
    dv6620ev_original.bin
    AND HERE NEW FILE FROM HP SUPPORT SITE
    dv6620ev.bin
    SEE INSIDE BIOS.RAR FOR FILES
    PLEASE GIVE ME A GUIDELINE HOW TO FIX THOSE FILES BECAUSE IS COMMON ISSUE IN HP LAPTOPS. PLEASE HELP ME
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Hp dv6620ev bios - -too long file please help
    used you new file, cut extra data, pasted dmi data from backup bin and name it as final.bin
    here you go, hope it helps
    Im Back... sort of...
    • kazia
      • May 2015
      • 145
      • indonesia
      dear friend, can you tell me how to cut extra data, pasted dmi data from backup, got same problem on different laptop. thanks
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        all done manually with hex editor
        • kazia
          • May 2015
          • 145
          • indonesia
          can't do that without any tutorial,
          please fix it for me....
          • balattc
            • Feb 2015
            • 153
            • india
            hi proposa
            u no need to edit hp website bios its too hard
            pls post ur laptop model name clearly,
            series name v6
            model name : ?
            board number :?
            bios rev :?
            chipset : nvidia , amd , ati , intel ?
            post clearly
            others give easy to give ur bios bin
            then u easy flash with ur programmer
            thanks in advance
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              ok friend try this
              • kazia
                • May 2015
                • 145
                • indonesia
                ok friend try this
                Thank You my friend..
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
                • Forest79
                  by Forest79
                  07-23-2023, 07:39 AM
                • maanee11
                  Help to get Lenovo BIOS bin file for Thinkpad T560
                  by maanee11
                  Hello Everyone,
                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                  05-15-2022, 11:59 AM
                • Sebastian Codrean
                  BIOS file for ASUS F542UN laptop
                  by Sebastian Codrean
                  Hello to all of you! I need help with a BIOS file.
                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                  02-20-2025, 10:25 AM
