HP 840 G1 Unlock MPM issue
  • techrefurbca
    • Apr 2023
    • 25
    I have a bios for HP 840 G1 that shows this message: The Embedded Controller MUD data is not valid while MPM is locked, but when I accept, it says The Embedded Controller flash failed.
    Attached are images of the laptop model and error message, also bios dumps.
    HP G1 - Copy.zip
    Can you please help me get rid of this error message?
    Thanks!
  • Ninel_CZ
    HP EliteBook Folio 1020 G1 - BIOS issue
    by Ninel_CZ
    Hello Masters of BIOS heaven,
    I am kindly asking for your help. I had bricked HP EliteBook Folio 1020 G1, after flashing both BIOS chips by files from this site, NTB start working but I am gettin message:Embedded controller data MUD is not valid while MPM is locked. Please unlock MPM, and lock again to capture valid MUD data.
    I am posting 4 files:
    MX25L1673 bricked.bin - original one before flashing
    winbond 25Q128 bricked.bin - original one before flashing
    MX25L1673E locked MPM.bin - locked MPM after flash
    winbond 25Q128 locked MPM.bin - locked...
    01-13-2023, 02:15 PM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • qth2010com
    issue Bios unlock Elite Tower 600 G9 PC
    by qth2010com
    i need file unlock for elite 600. so many thanks...
    07-31-2023, 12:13 AM
  • Grouickman
    Hofmann geodyna 6300 Wheel balancer
    by Grouickman
    Hi there,
    First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
    Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
    I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
    I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
    03-31-2025, 05:29 AM
  • ugamazing
    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
    by ugamazing
    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
    12-17-2024, 07:05 PM
