Lenovo 14W GEN 2
  • spicetech
    • Sep 2024
    • 3
    • France
    Lenovo 14W GEN 2
    I new to this forum. I alredy searched this forum but not found any informations so i decided to post here. A friend of mine had a Laptop Levono 14W Gen 2 with mother board 203105-1M. The bios was locked so he bought a CH341A and deleted the bios to flash a new. the pc has a black screen. so he tried to took of the bios chip wich is GD25lq128dsig and the broked. He brought me this Pc to check. So i decided to order a new chip from Ali and i flashed a new dump found here in the forum and none work.The pc still has a black screen. I tried Asprogrammer and neoprogrammer the chip is detected and flashes bios but everytime black screen. I dont know whether it comes from the bios or from eleswhere. So someone can help plz. The bios i flashed is attached. Thanks for you help.
    Lenovo 14W GEN 2
    S/N:R912YC4H
    Motherboard model 203105-1M
    • 21472
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • DDuke
      • Sep 2025
      • France
      Have you found any solution, I have the same Issue but I see you have a 14W Gen 2 Laptop (Lenovo) - Type 82N9 an not 81mq.
      Regards
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • jendkkd jeje
        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
        by jendkkd jeje
        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
        10-11-2024, 03:12 PM
      • 1g0r
        Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
        by 1g0r
        First, the data in brief:
        Manufacturer: Lenovo
        Model: ThinkPad L15 G3 21C3-0016GE
        motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
        IC Bios 1: MX77L25650F
        IC Bios 2​: MX25L25673G
        EC Chip: NPCX997KAABX
        So far I've been a silent reader, but now I need your help
        I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
        I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
        The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
        01-18-2025, 02:39 AM
      • c.daniel
        Lenovo V310-15IKB weird bios problem...
        by c.daniel
        Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
        sn LR09493E
        MB DAOLV6MB6F0 REV. F
        The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
        Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
        Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
        08-22-2025, 05:39 AM
      • Loli Popu
        DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 03:28 AM
