bricked bios on thinkbook 15 g2 itl
  • shiyab
    • Sep 2023
    • 1542
    • india
    Originally posted by huss584
    Need Help Please any Update ?
    hi try both file flash
    • huss584
      Hussein
      • Apr 2020
      • 229
      • Palestine
      Hello
      I reprogram the BIOS file but the power Led Light for 5 second continuously
      • shiyab
        • Sep 2023
        • 1542
        • india
        Hello
        flash both
        • huss584
          Hussein
          • Apr 2020
          • 229
          • Palestine
          Originally posted by shiyab
          flash both
          I do that and I use another BIOS Chip working 100% Same Problem
          • shiyab
            • Sep 2023
            • 1542
            • india
            bord issu
            • Fr33man
              BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
              by Fr33man
              I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
              *Novo button power on
              *Disconnected internal battery...
              09-23-2024, 01:16 PM
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
            • pcwhiz24
              Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
              by pcwhiz24
              Model: Lenovo IdeaPad 3 14ADA05 81W0
              S/N: PF2BZS7D
              I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
              I already have a CH341A programmer...
              04-07-2025, 07:10 PM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • m1ch43lzm
              Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
              by m1ch43lzm
              Hi everyone
              I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
              Programmer models: XGecu TL866II Plus / T48 / T56 / T76
              Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
              There's also an extra OTP Secu.R...
              09-06-2025, 05:47 PM
