Samsung NP300E5C bios dump needed
  • noname2024
    • Aug 2024
    • 295
    • CỎ MỸ XỊN
    #61
    Originally posted by L.L.
    Greetings all, could you please assist with the unlocking of this BIN
    Samsung NP300E5C
    Board Number: BA41-01979A
    I've tried many files and it didn't work.
    Please find attached the BIN
    try Click image for larger version
    • L.L.
      • Jun 2023
      • 16
      • Argentina
      #62
      Thanks noname2024
      Although my bios was: P04RAJ
      "SECWUP�P04RAJ�021�0000�00�00�LG�300E4C..."
      It worked OK​
      • noname2024
        • Aug 2024
        • 295
        • CỎ MỸ XỊN
        #63
        Thanks noname2024
        It worked OK​
        you can flash bios ver P04RAJ
        • L.L.
          • Jun 2023
          • 16
          • Argentina
          #64
          What happens if I leave P09?
          • 505notfound
            • Jul 2025
            • 4
            • Romania
            #65
            I use a Samsung NP300E5C but it cant enter bios setup. Can anyone give me a stock non-modded P07RAC or P04RAC ROM?
              • 22283
              Thread merged. Type the laptop serial number, full name and model, motherboard model, etc.
              post the contents of the bios chip even if it is corrupted..
              read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
              • noname2024
                • Aug 2024
                • 295
                • CỎ MỸ XỊN
                #67
                Try flash p09
                • 505notfound
                  • Jul 2025
                  • 4
                  • Romania
                  #68
                  its NP300E5C with a BA92-10824B mobo and has a corrupt p07rac installed
                  • 505notfound
                    • Jul 2025
                    • 4
                    • Romania
                    #69
                    also here are the contents extracted with universal bios backup toolkit from m-a-j-o-r-g-e-e-k-s
                    • Nello99exc
                      • Sep 2025
                      • Italy
                      #70
                      Good morning/evening to everyone,
                      I'm a new member of this forum!
                      I’m looking for a clean, working BIOS dump for the following Samsung laptop motherboard:
                      • Model: Samsung NP300E5C-S05IT
                      • Motherboard: SCALA3-15/17CRV
                      • Board code: BA41-01979A
                      • PCB Revision: Rev 1.0
                      • BIOS chip: GigaDevice GD25Q64BSIG (8MB)
                      The original BIOS chip is faulty and needs replacement and reprogramming.
                      Most BIOS dumps I’ve found online are for BA41-01979A Rev 1.2, but I need one that is confirmed working with **Rev 1.0**, ideally dumped from a working board with the **same revision**.
                      If you have this dump or access to it, I’d really appreciate your help.
                      Also, if you have any working Rev 1.0 version BIOS (even for a different chip brand like MX25 or W25), please let me know.
                      Do you know if the BIOS for the SCALA3-15/17CRV REV 1.2 motherboard (BA41-01979A) is also compatible with the REV 1.0 version of the same board?
                      Thanks in advance!
                      Nello99exc
                      • noname2024
                        • Aug 2024
                        • 295
                        • CỎ MỸ XỊN
                        #71
                        Thanks in advance!
                        Nello99exc
                        • Nello99exc
                          • Sep 2025
                          • Italy
                          #72
                          Thanks a lot noname2024
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • TacticalFahrrad
                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                            by TacticalFahrrad
                            I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                            BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                            06-30-2025, 04:09 AM
                          • Kjell
                            Samsung Series 9 - BIOS issue
                            by Kjell
                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                            08-01-2025, 09:15 AM
