Samsung NP300E5C bios dump needed
you can flash bios ver P04RAJAttached Filesif you find these attachements useful please consider making a small donation to the site
I use a Samsung NP300E5C but it cant enter bios setup. Can anyone give me a stock non-modded P07RAC or P04RAC ROM?Comment
Thread merged. Type the laptop serial number, full name and model, motherboard model, etc.
post the contents of the bios chip even if it is corrupted..
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
its NP300E5C with a BA92-10824B mobo and has a corrupt p07rac installed
also here are the contents extracted with universal bios backup toolkit from m-a-j-o-r-g-e-e-k-sAttached Filesif you find these attachements useful please consider making a small donation to the site
Good morning/evening to everyone,
I'm a new member of this forum!
I’m looking for a clean, working BIOS dump for the following Samsung laptop motherboard:
• Model: Samsung NP300E5C-S05IT
• Motherboard: SCALA3-15/17CRV
• Board code: BA41-01979A
• PCB Revision: Rev 1.0
• BIOS chip: GigaDevice GD25Q64BSIG (8MB)
The original BIOS chip is faulty and needs replacement and reprogramming.
Most BIOS dumps I’ve found online are for BA41-01979A Rev 1.2, but I need one that is confirmed working with **Rev 1.0**, ideally dumped from a working board with the **same revision**.
If you have this dump or access to it, I’d really appreciate your help.
Also, if you have any working Rev 1.0 version BIOS (even for a different chip brand like MX25 or W25), please let me know.
Do you know if the BIOS for the SCALA3-15/17CRV REV 1.2 motherboard (BA41-01979A) is also compatible with the REV 1.0 version of the same board?
Thanks in advance!
Nello99exc
SCALA3-15/17CRV REV 1.2Good morning/evening to everyone,
Thanks in advance!
Nello99excAttached Filesif you find these attachements useful please consider making a small donation to the site
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
by KjellAfter installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...08-01-2025, 09:15 AM - Loading...
