Toshiba Satellite C850D no video, maybe bios needed
  • Scootie
    • Feb 2014
    • 133
    • Romania
    Hi there,
    Im trying to work on this C850D-108, PSC9WE.
    At powerup a white led stays on but no signal on screen or vga output. The unit accepts shutdown. While powered on the NB and CPU(soldered to bord) gets warm and the SB gets really warm after about 30 seconds.
    I was thinking that either the NB or SB needs reball but I wanted to update the bios first but I couldnt find a proper bios file for it or the schematic to identify the chip version.
    I'd apreciate some help on this matter from anyone who had prior experience with this model.
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Re: Toshiba Satellite C850D no video, maybe bios needed
    I'm having the same symptoms you have in a C850D-125. But I'm past BIOS, it seems a BIOS problem but I still couldn't fix it yet. You can follow my thread here.
    https://www.badcaps.net/forum/showthread.php?t=36733
    I found your BIOS here. Attached it to the thread.
    http://www.toshiba.se/innovation/dow...=16&service=ND
    Good luck, L2D.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
    • Scootie
      • Feb 2014
      • 133
      • Romania
      That bios file I found as well and wonder if PLCBX8.FD is the bios package?! Cause in the Win7 dir the file is 2MB while in Win8 is 4MB.
      Btw, did u manage to locate the bios chip? Can you show me? Without schematic I cant decide which of the 2 chip nearby the NUOVOTON it is.
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        Yes, PLCBX8.FD is the bios file. Size difference is due to Windows 8 license and others related to Windows 8.
        Visit my thread and see if BIOS chip and board reference matches, my chip is Winbound and it's located on the left of the card reader. You could easily avoid this question if you read it first.
        Try Harder!
        • Scootie
          • Feb 2014
          • 133
          • Romania
          I read your thread but my motherboard has a nuvoton chip and even the chip which I suspect is the bios has a different location then yours.
          • Learn2Day
            • Jun 2013
            • 254
            • Portugal
            Post board reference for schematics.
            Try Harder!
            • Scootie
              • Feb 2014
              • 133
              • Romania
              Plabx/csabx Rev: 2.1 is only thing I found on it.
              • Learn2Day
                • Jun 2013
                • 254
                • Portugal
                Watch this.
                http://www.elvikom.pl/forum/viewtopic.php?f=66&t=24877
                You might want to look closer. According to that thread all points to a Winbond chip.
                Try Harder!
                • Scootie
                  • Feb 2014
                  • 133
                  • Romania
                  I'll check tuesday morning and make a picture too.
                  • kotnatan
                    Banned
                    • Apr 2014
                    • 181
                    • Ukraine
                    Pegatron PLABX/CSABX UMA&DSC rev:2.1
                    • Scootie
                      • Feb 2014
                      • 133
                      • Romania
                      That's the one idd.
                      • Scootie
                        • Feb 2014
                        • 133
                        • Romania
                        Here are the partial pictures of the board. The chip is a Nuvoton NPCE795LA0DX. Im not sure which of the two chips contains the bios flash(red circle or blue square). Since I dont have the schematic I also find it difficult to identify the chip version in order to flash it with my programmer.
                        • lezsimply
                          The Wanderer
                          • 645
                          • Philippines
                          blue one but cannot identify part number. please input markings on chip if possible.
                          • Scootie
                            • Feb 2014
                            • 133
                            • Romania
                            If I managed to read it correctly:
                            MXIC M*
                            25L1606E
                            • lezsimply
                              The Wanderer
                              • 645
                              • Philippines
                              This is most likely MX25L1606E by Macronix (MXic) so that concludes it is bios chip.
                              • Scootie
                                • Feb 2014
                                • 133
                                • Romania
                                Yes, I managed to flash it but the same problem persists. Laptop start, power indicator is on but no vga signal on lcd or vga out.
                                • Learn2Day
                                  • Jun 2013
                                  • 254
                                  • Portugal
                                  Scootie, check this thread for schematics.
                                  https://www.badcaps.net/forum/showthread.php?t=37066
                                  Try Harder!
                                  • Scootie
                                    • Feb 2014
                                    • 133
                                    • Romania
                                    Thanks, I saw it but that's an intel board schematic and mine is AMD. I took off today the vga chip and reballed it, tomorrow will put it back togheter and see what happens.
                                    • toni31
                                      • 44
                                      • Thessaloniki
                                      check this out
                                      • Scootie
                                        • Feb 2014
                                        • 133
                                        • Romania
                                        Well, im passed now the bios. I flashed it but the laptop was still not showing signs on the screen so I took off the gpu, reballed it and put it back. The laptop does the same thing, powers up, power led on, but no screen. I dont know what else to do with it.
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                        • menshawy
                                          Toshiba satellite pro A50-D bios needed
                                          by menshawy
                                          hi friends
                                          pleas i need Toshiba satellite pro A50-D-17R,PS585E
                                          M.B : FLEKSY1 A4363A
                                          problem : black screen after toshiba logo , i cant enter to bios setup
                                          old bios
                                          02-08-2024, 01:58 PM
                                        • mui
                                          Toshiba satellite pro 30-d-14k Bios Dump needed
                                          by mui
                                          Anyone who can help remove pasword on satellite pro 30-d-14k bios here is a dump
                                          post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.....
                                          05-02-2025, 05:12 AM
