Asus Laptop FX505DT BIOS Help
  • jotati7062
    • Jan 2024
    • 12
    • SA
    Hello Everyone, I have this Asus Laptop FX505DT BIOS ON, I looked in the Forum for same model maybe I can do the work but not many posts related to BIOS ON
    please check uploaded bios file attached. Thank u
    Need BIOS OFF.
  • peste
    • 12792
    • ROMANIA
    Need BIOS OFF.
    read the rules..https://www.badcaps.net/forum/troubl...before-posting
    post the S/N, the motherboard model, the full name and model of the laptop,etc.
    • jotati7062
      • Jan 2024
      • 12
      • SA
      Update,, i was able to find the word in question, i did follow this post
      https://www.badcaps.net/forum/troubl...66#post1544866
      toke me good hour to understand it lol
      bottom line
      --read bios chip
      --use any hex editor app
      --search for AMITSE
      --there will be one area that has random text after AMITSE in my case looked like this
      "AMITSESetup ìÚ&\∫%Mâ‡"t}ÿö3.é¡ÈTDËü{˙U¢∞5 …f\¡ÔÉ NVAR"
      or in hex"1A93F2265CBA254D89E022747D07D89A332E8EC1E95444E89F7BFA0E55A2B0350BC9665CC1EF1C83"
      -- copy the hex value of That code/text ONLY, removed spaced from that hex value and used that value in the website "https://xor.pw"
      --in the website Input 1 add your hex value without spaces
      --in input 2 just add as is (remove space between F and 7) 5B93B62611BA6C4DC7E022747D07D89A332E8EC1E95444E89F 7BFA0E55A2B0350BC9665CC1EF1C83
      --in output 3 change it to "ASCII Base256"
      --then click Calculate
      you should see the word your looking for
      in my case it was ADMIN "check attached pic"
      i was so mad not to try such thing before taking the device apart lol
      anyway i learned something & hopefully someone will one day need the same thing
      Enjoy !!
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • Bloodhoundje
        by Bloodhoundje
        03-16-2024, 03:12 PM
      • JoWed
        Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
        by JoWed
        Hello Community,
        I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
        07-01-2025, 09:32 AM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
