hp spectre x360 13-4129na blinking cap lock no post
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Originally posted by Billy1690
    This might be a stupid question bud do I have to have the ssd installed in the machine after programming the bios chips
    nope , if you can get to post the board your good to go , you might try finding a good working ram or try to dissemble the board try using external monitor and only board , ram and if you jumper the power button you can do it also to just isolate the probability of some hardware issue
    • Billy1690
      • Aug 2024
      • 46
      Great idea I’ll try connecting it to the tv with a hdmi later and see if that works
        • 22289
        Your CPU is skylake. It can`t be the 1st bios as that has ME 10 firmware, or the last one as thats too big. 0804E and F have ME 11 firmware, so its one of those. The 5:3 error can sometimes be caused by loose ram slot pins,so check all those carefully.
        • Billy1690
          • Aug 2024
          • 46
          No worries its onboard ram ill double check the solder joints on the ram later thanks again for all your advice ill go and put another donation in just now and ill keep you updated on how i get on with connecting to hdmi to tv and checking solder joints
          • Billy1690
            • Aug 2024
            • 46
            Now i checked everything and tried all the files again olso checked with hdmi to tv i have another board doing the exact same thing 5x3 cap lock flashes the other board was working great until i accidentally knocked 2 caps off with the crocodile clip taking a coppy of the bios file i replaced the caps but same thing i managed to get a replacement board so these two boards are for experimenting i was looking to get one up and running for a spare but im running out of ideas
            • Billy1690
              • Aug 2024
              • 46
              #26
              Im thinking its a hardware issue probably the onboard ram went bad with the wrong bios been flashed if thats possible
              • Billy1690
                • Aug 2024
                • 46
                #27
                Does anyone know the number of the bios chip of the hp spectre x360 13-4129na as the numbers on my chip are gone I’ve ordered a different programmer and I’m looking to program a new chip I’m thinking the original chip could be faulty
                  • 22289
                  Does anyone know the number of the bios chip of the hp spectre x360 13-4129na as the numbers on my chip are gone I've ordered a different programmer and I'm looking to program a new chip I'm thinking the original chip could be faulty
                  There are 3 different bios chips listed in the motherboard schematic
                  EN25QH64-104HIP 1C7017
                  W25Q64FVSSIQ EF4017
                  GD25B64BSIGR C84017
                  And in the 0804E/F bios these chips are in the VSCC table
                  Flash chips in VSCC table:
                  EF4017 (Winbond W25Q64)
                  1C7017 (EON EN25QH64)
                  C84017 (GigaDevice GD25x64)​
                  • Billy1690
                    • Aug 2024
                    • 46
                    #29
                    Smdflea thank you do you know where I can buy them from or do I get the from AliExpress
                      • 22289
                      Ali is cheapest. Buy W25Q64FVSSIQ or GD25B64BSIGR .
                      • Billy1690
                        • Aug 2024
                        • 46
                        #31
                        Fantastic buddy thanks again for your help I’ll go get them now 👍😉
                        • Billy1690
                          • Aug 2024
                          • 46
                          #32
                          SMDFlea i got the T48 programmer but got sent these W25Q64FVSSIG chips will they still do the job or does it have to be one of these W25Q64FVSSIQ / GD25B64BSIGR
                          • alihomee
                            • Dec 2012
                            • 1599
                            • malaysia
                            #33
                            i am having same model withsame motherboard code....orignal file got password...i tried 2 fikles from this post...both work but product info missing and program manufacture mode is alwtas there...i attached orignal password protected file
                              • 22289
                              This thread is for the specific model number in the thread title 13-4129na is yours the same model ?.There is no motherboard number in the thread title. If yours isn`t the 13-4129na then go find a thread with the motherboard number in the thread title or find a thread for your specific model, if you can`t find one then start a new thread, and include the elusive serial number and other info that you always forget to post....
                              • alihomee
                                • Dec 2012
                                • 1599
                                • malaysia
                                #35
                                yes my motherboard is same as provided by billy1690....and it is DAY0DEMBAB0 with model:13-4129TU and my serial num is: 5CD6217ZD9....i just wana remove password fron ori file...in tried with RC unlocker and HP unlock tool also but it show error contant missing....
                                  • 22289
                                  Start a new thread.. .The unlockers won`t work ,the consumer machines have an Insyde bios, business machines have AMI bios
                                  • m1ch43lzm
                                    • Mar 2019
                                    • 1126
                                    • Peru
                                    #37
                                    HP is starting to delete all info for these models previous to 2015, found the HP Spectre 13-4000 x360 drivers support page but not the specific 13-4129na page, it may not last long
                                    SMDFlea on HP the last digits don't matter... same laptop just different specs/region
                                    https://support.hp.com/au-en/drivers...ble-pc/7527520
                                    Reupload BIOS extracted from https://ftp.hp.com/pub/softpaq/sp101...0/sp101310.exe (HP still keeps the softpaqs but deletes the support pages)
                                    BIOS Version: F.54, BID: 0804F, 0804E, 0802D, 08035
                                      HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                      This specification for the HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 13-aw0197tu boardview and Spectre x360 - 13-aw0197tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-06-2024, 12:10 PM
                                      HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                      This specification for the HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 Conv13-aw0054na boardview and Spectre x360 Conv13-aw0054na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      09-06-2024, 11:50 AM
                                      HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                      This specification for the HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-df0068nr boardview and Spectre x360 - 15-df0068nr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-06-2024, 07:20 AM
                                      HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                      This specification for the HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-ch050na boardview and Spectre x360 - 15-ch050na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-06-2024, 06:21 AM
                                      HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      09-06-2024, 11:39 AM
