hp spectre x360 13-4129na blinking cap lock no post
  • Billy1690
    • Aug 2024
    • 46
    Hi lads im looking for a hp spectre x360 13-4129na /serial:5CD6430N9W bios dump file please to sort out a corrupt bios any help would be great
  • peste
    • 13422
    • ROMANIA
    post the original bios of the laptop even if it is corrupted.
    • Billy1690
      • Aug 2024
      • 46
      Unfortunatly the bios was flashed with the wrong dump file causing the issue
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        can you post the motherboard code that is printed to it, so we can rebuild your bin for you
        • Billy1690
          • Aug 2024
          • 46
          HI BUDDY THE MOTHERBOARD CODE IS DAY0DEMBAB0 REV:B
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            try this
            • Billy1690
              • Aug 2024
              • 46
              Hi kalilinux25​ thanks very much for your help ive tried a couple of files includiing this one you sent me what im getting is the f5 light lighting up on the key board and five slow blinks on the cap lock and three fast wondering if the motherboards faulty
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                lets wait for some other help maybe can help you with this
                • Billy1690
                  • Aug 2024
                  • 46
                  Ok no worries buddy thanks again for your help
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    can you try cleaning the ram of changing the ram??
                    • Billy1690
                      • Aug 2024
                      • 46
                      Unfortunately the ram is on board on this model
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        maybe its a ram chip issue
                        • Billy1690
                          • Aug 2024
                          • 46
                          I lost two caps using the clamp that comes with the programmer i would never use the clamp again i replaced them with two from another board the caps i replaced are the ones around the bios chip the white one and the brown one it could be ive not soldered them properly im thinking
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            or maybe you swap its possitons
                            • Billy1690
                              • Aug 2024
                              • 46
                              Ill have another go over the next few days to make sure ive done everything ok ill need to get a digital microscope ive been using these Head Magnifier With a led Light they are ok but not the best
                              • Billy1690
                                • Aug 2024
                                • 46
                                Ok I’m 95% sure I’ve put the caps on properly still getting the flashing caps 5 slow 3 fast so back to the drawing board šŸ˜„
                                • peste
                                  • 13422
                                  • ROMANIA
                                  Ok I'm 95% sure I've put the caps on properly still getting the flashing caps 5 slow 3 fast so back to the drawing board šŸ˜„
                                  bios extracted from the HP website update for HP Specter x360 - 13-4129na (ENERGY STAR), the laptop has four bios variants.. if you no longer have the original bios, try them in turn..
                                  DMI 61CF00 - 61D0FF
                                  KEYWIN 63E000 - 63E03F
                                  • Billy1690
                                    • Aug 2024
                                    • 46
                                    I’ll give them all a go when I get home thanks very much I’ll keep you posted on how I get on šŸ‘
                                    • Billy1690
                                      • Aug 2024
                                      • 46
                                      Ok tried the first one laptop didn’t power on then I tried the second and third file's but the same issue 5 slow three fast the fourth file said it was to big for the chip so I didn’t try it so I’m thinking it’s a faulty motherboard
                                      • Billy1690
                                        • Aug 2024
                                        • 46
                                        This might be a stupid question bud do I have to have the ssd installed in the machine after programming the bios chips I’ve just been looking for the image on the screen
                                          HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                          This specification for the HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 13-aw0197tu boardview and Spectre x360 - 13-aw0197tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 12:10 PM
                                          HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                          This specification for the HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 Conv13-aw0054na boardview and Spectre x360 Conv13-aw0054na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 11:50 AM
                                          HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                          This specification for the HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-df0068nr boardview and Spectre x360 - 15-df0068nr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:20 AM
                                          HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                          This specification for the HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-ch050na boardview and Spectre x360 - 15-ch050na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 06:21 AM
                                          HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 11:39 AM
