Question about recovering Asus bios password
  • Spakye
    • Aug 2024
    • 18
    • France
    Hello, this is my first post on the forum, my apologies if i don't post in the right place.
    Im trying to recover an asus bios password using this method.
    I follow every step and it seems to work out well because i get a password but sadly the password doesn't work.
    In my case, there is 2 times the same string that perfectly match the decyption hex, so my guess was that there is an user & an admin password and they are the same.
    This is the string "0993C72677BA5C4DF3E012744407E89A0A2E8EC1E95444E89F7BFA0E55A2B0350BC9665CC1EF1C83".
    I would really like to understand what im doing wrong.
    I don't know if its relevant but the computer is an asus tuff FA506ICB-HN173 Motherboard DANJIMB18A0 Rev A
ID:	3340773Click image for larger version
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1369
    • France
    Same Click image for larger version
    ​post the complete bios
    and serial number of the machine to respect the forum rules.
    Have you tried cleaning the area?
    The password comes back?
    • Spakye
      • Aug 2024
      • 18
      • France
      Alright my bad here it is:
      Serial Number: N9NRCX10B441398
      No i didn't try on this laptop, the full story is i bought 10 asus tuf laptops locked by bios password. My idea was to try to fix them to resell them.
      Anyway, on the first laptop i tried to recover the password with the same method and the password i got was not working, i then tried to blank the password in the bin file but that didn't work either as the pc was still asking for a password.
      I will try to clear that one also and see if it works this time.
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1369
        • France
        try
        • Spakye
          • Aug 2024
          • 18
          • France
          So i did try to clear the password myself, it didnt work the laptop was still asking for a password.
          Then i tried with your bin file and it worked!
          Thank you very much, do you mind me asking what did you blank exactly? I see in your bin file you did remove the password the same way i did, did you do anything else?
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1369
            • France
            compare with HxD and F6 and look difference
            • Spakye
              • Aug 2024
              • 18
              • France
              ok i took a look i get the idea, thank you very much!
              • volinakis
                • Jan 2021
                • 2876
                • N/A
                Originally posted by Maxpower3
                Same Click image for larger version  Name:	image.png Views:	19 Size:	64.5 KB ID:	3340792
                i think is Raf040909 (for sure he has french layout keyboard). BTW, your xls decrypter file works great but sometimes it misses a special character, i.e. it missed "!" at the end of password.
                • volinakis
                  • Jan 2021
                  • 2876
                  • N/A
                  decrypted passwords are for US layout keyboard, if you use external USB US keyboard it will work or try Raf040909 from your french layout laptop keyboard.
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1369
                    • France
                    well seen,
                    for the descriptor, yes some errors, I will look at that occasionally
                    • Spakye
                      • Aug 2024
                      • 18
                      • France
                      Well i won't try on this laptop because thanks to Maxpower there is no more password.
                      But i've just opened an other one and tried the same thing and it doesnt work aswell.
                      Ive tried Cqlvisqc & Calvisac, Ive tried to look up for differences other than A-Q on US-FR keyboard but nothing that would matter for this password. Not sure what else i can do. I don't have an US keyboard sadly.
                      Serial Number: N4NRCX05N534165
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        If decode fails, delete password.
                        • Spakye
                          • Aug 2024
                          • 18
                          • France
                          Yes I will try, just wanted to see if im missing something.
                          • volinakis
                            • Jan 2021
                            • 2876
                            • N/A
                            it means you have 2nd password, if you compare 1st bios you see it repeats 2 times, meaning bios pass and/or power on pass/hdd pass are the same.
                            2nd password is: calvisac (with small c)
Name:	Screen Shot 2024-09-01 at 13.16.01.png
                            • Spakye
                              • Aug 2024
                              • 18
                              • France
                              Originally posted by volinakis
                              try Calvisac
                              I tried already it didn't work, i will try to clear it.
                              Thank you for helping out.
                              • volinakis
                                • Jan 2021
                                • 2876
                                • N/A
                                I modified my post, try calvisac (with small c)​
                                • Spakye
                                  • Aug 2024
                                  • 18
                                  • France
                                  Found it!
                                  As i was going to clear it i was looking through the bin file and found an hex almost identical to the one posted above, the only difference is it start with 38 instead of 18 which gives a "c" instead of a "C".
                                  I then tried "calvisac" and it worked.
                                  Lesson learned for next time. Thank you guys for the help.
                                  • pirati
                                    by pirati
                                    10-27-2025, 04:20 PM
                                  • touftaf7301
                                    ASUS TUF A17 – BIOS password removal request
                                    by touftaf7301
                                    I have an ASUS TUF A17 (model TUF707NV-HX088W, motherboard NJS / DA0NJSMBAF0 Rev F) that is locked by an UEFI BIOS password.
                                    I have already checked the BIOS guides, methods, resources and tools section but could not find a working method for this specific model.
                                    Details:
                                    – Make/Model: ASUS TUF A17 TUF707NV-HX088W
                                    – Motherboard: NJS / DA0NJSMBAF0 Rev F
                                    – Serial number: S7NRCX05W03829E
                                    – Issue: UEFI BIOS password locked (no access to BIOS setup or boot options)
                                    – BIOS dump attached below (read with RT809F)...
                                    11-07-2025, 02:15 PM
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • snpetit
                                    Asus FA706IH Bios Password remove
                                    by snpetit
                                    i need some help :-/
                                    i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                    Could you please remove all password related stuff from this bios. A hate Asus....
                                    Thanks in advance!...
                                    01-10-2025, 09:17 AM
