HP Elite x360 830 G10 2-in-1 bios unlock
  • shiyab
    • Sep 2023
    • 1478
    • india
    #41
    Originally posted by virusjez
    can you help me unlock
    hp elite x360 830 g10 2-in-1
    SN - 5CG4180ZBW
    ProdID:8Q416UP#ABA
    hi try
    • madjid911
      • Dec 2016
      • 390
      • France
      #42
      Hello, can you help me unlock this laptop please?
      hp Elitebook 830 G10
      SN : SCG4074KD0
      • Blaze Tech
        Learner
        • 205
        • Ghana
        #43
        Originally posted by PedroHS29
        Hello guys,
        I have a question for you, I need to clear the bios administrator password (the password that you need enter when you try to access to rhe bios settings - F10 press key) I don´t have Bios POST password, i can turn on perfectly the computer and enter to windows because the PC don´t have POST Bios password, this PC only have configure Bios Administrator password to enter to the BIOS setup.
        Then i need to clear this password, i think that this password it´s located in EC ROM chip but it am not sure 100%. In this way, i attached you the two files dump (EC ROM and BIOS CHIP files).
        Can you help me to unlock this PC? And give me the correct steps to do the procedure??
        PC information
        - Model: HP EliteBook x360 830 G10 2-in-1
        - S/N: 5CG4194G2M
        - ProdID: 6V439AV
        Thanks in advance!
        try
        • madjid911
          • Dec 2016
          • 390
          • France
          #44
          Originally posted by Blaze Tech
          try
          I tried, I still have the BIOS password. I had already tried with RCUnlocker it did not work that is why I ask you for help please to help me unlock this bios
          • farouk_1994
            • Mar 2021
            • 392
            • algeria
            #45
            Try,after enter bios reset bios to default than enter bios and reset security to default than get yout original bios back
            • madjid911
              • Dec 2016
              • 390
              • France
              #46
              thanks its works
              • jymmytuan95
                • Jan 2021
                • 30
                • Viet Nam
                #47
                PLEASE UNLOCK PASSWORD HP X360 830 G10 6050a3437501-mb-a02
                SERI 5CG4084DP3​
                • anhbanxoi
                  • Sep 2021
                  • 172
                  • VN
                  #48
                  SERI 5CG4084DP3
                  Product Name : HP Elite x360 830 13 inch G10 2-in-1 Notebook PC
                  Serial Number: 5CG4084DP3
                  SKU : 6V448AV
                  BuildID : 23WWWGBZ602#SABU#DABU
                  Feature Byte : 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbVbhcAd6fPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.2B
                  System Board CT Number : PRNCC00WBJ6192​
                  • jymmytuan95
                    • Jan 2021
                    • 30
                    • Viet Nam
                    #49
                    SKU : 6V448AV
                    TKS BRO! PASSWORD NOT REMOVED
                    • shiyab
                      • Sep 2023
                      • 1478
                      • india
                      #50
                      SKU : 6V448AV
                      hi try and feedback
                      • jymmytuan95
                        • Jan 2021
                        • 30
                        • Viet Nam
                        #51
                        • jafasbay@gmail.com
                          • May 2019
                          • 19
                          • mocambique
                          #52
                          rex98 i cant download the file.can you post again pls
                          • rex98
                            • Feb 2023
                            • 1278
                            • Mandaue CEBU, Philippines
                            #53
                            I noticed there's a lot of unlock request for this model HP Elite x360 830 13 inch G10 2-in-1 & HP EliteBook 830 13 inch G10
                            The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
                            first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                            use BCU and put your original DMI.
                            This bios will work in this 2 models: HP Elite x360 830 13 inch G10 2-in-1 & HP EliteBook 830 13 inch G10
                            This is only for BID V70 only if you have different BID it won't work.​
                            • zubair12
                              • Dec 2022
                              • 8
                              • Dubai
                              #54
                              hp elitebook x360 830 G10 2 in 1
                              SERIAL NO 5CG336593N
                              PLZ UNLOCK THIS FILE
                                • 20949
                                Your BID is V70 ,read the post above https://www.badcaps.net/forum/troubl...19#post3672319
                                • zenius
                                  by zenius
                                  12-08-2024, 06:13 AM
                                • gsm4all
                                  HP Elite x360 830 G9 2-in-1 bios unlock
                                  by gsm4all
                                  hello, need help with bios unlocking
                                  6050A3316601-MB-A01
                                  2022-01-20
                                  HP Elite x360 G830 G9 2-in-1...
                                  10-07-2023, 07:16 AM
                                • Andrew Bower
                                  BIOS Unlock for HP zbook studio x360 g5
                                  by Andrew Bower
                                  I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
                                  That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....
                                  12-04-2024, 05:55 PM
                                • Syavko1
                                  Unlock Bios HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                  by Syavko1
                                  Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                  I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? ​
                                  01-22-2025, 02:04 PM
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
