HP Elite x360 830 G10 2-in-1 bios unlock
https://www.badcaps.net/donate -
Hi hoaca388 ,
I flash bios ic and ec rom mod that you send me and i solder again both chips in the motherboard and when i try to enter to the bios setup, the pc continue request me the bios administrator password. Nothing change with these files.
Can you help me?? Something is wrong.
No chance to reset to factory settings ?
Hi hoaca388 ,
https://www.badcaps.net/donateComment
No, i can not enter to bios setup in the first boot after flash dump mod files that you send me. When i press F10 key in the first boot continue display to enter bios administrator password again...
Can you send other files? Or tell me where i can delete the values where is located this password with HEX editor and in what ic, bios chip or ec rom?
I remenber that in elitebook g7 was located only in ec rom chip this password in line 37000.
I hope your feedback or help again
With the G10 series things are not so simple, it will restore from EC.
Then, what can I do to remove the bios administrator password to can enter in bios password?
because with first mod files was not working this method
Any help more or something to do?
Thanks in advance!Comment
Try !!Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi minhdigital,
Occur the same with these files, when i try enter to bios setup, appear the screen where request me the bios administrator password
Not working these files, do you have other alternative?
Regards.Comment
hello
can you help me reser the passowrd plz
hp elite x360 830 g10 2-in-1
SN - 5CG42006J5
write only main bios, leave EC as is. At 1st boot press F10 and restore factory defaults and restart. Before write new bios use BCU to get your laptop DMI and after write it use BCU again to write back DMI.Attached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I've told you, use BCU (Bios Configuration Utility) - I am using V4.0 - to get DMI before writing modified bios and after writing new bios which put your laptop in mpm (manufacturing program mode) use BCU to write back DMI. If you don't know how to use BCU search in this forum, i've posted how to use it. You also have a label inside bottom cover with your DMI, you can write those values entering in bios setup and in Main tab you have "Write machine unique data"----------------------------------------------------------------------------------------------------------------------------------------------------------------------
How can use Bios Configuration Utility to ream dmi
I've told you, use BCU (Bios Configuration Utility) - I am using V4.0 - to get DMI before writing modified bios and after writing new bios which put your laptop in mpm (manufacturing program mode) use BCU to write back DMI. If you don't know how to use BCU search in this forum, i've posted how to use it. You also have a label inside bottom cover with your DMI, you can write those values entering in bios setup and in Main tab you have "Write machine unique data"Comment
tried to unlock but still locked can someone help ?
hp elitebook 830 g10
sn: 5CG4165N35Attached Filesif you find these attachements useful please consider making a small donation to the site
can you help me unlock
SN - 5CG4180ZBW
ProdID:8Q416UP#ABAAttached Filesif you find these attachements useful please consider making a small donation to the site
Tested bios unlocked V70, main only flash it would boot to MPM.
you can use this in your HP Elite x360 830 13 inch G10 2-in-1 Notebook PC its already Clearme.
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU and put your original DMI.Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by whelanm87Hi everyone,
I’m working on a non-booting HP Envy x360 2-in-1 laptop and need verified firmware dumps for both the main BIOS and EC chip. I’ll be posting my own backups for reference and comparison.
🔍 System Details- Model: HP Envy x360 15-fe0053dx
- Product Number: 7HVO3UA#ABA
- Build ID: 23WW2GQZ6D
- Motherboard: JPR50 LA-M794P Rev: 1.0 (2023-03-03)
- Motherboard SPS: N30979-ABA
- LCD SPS: N49271-601
- Date Code: 172380
- Keyboard Type: 0
- Feature Byte:
3XeB7kN7.Ba.aqewkwBiBVuhcbdxYPgB
hZnp.praepq0Md4qkdf
🔧 Chip Info- Main BIOS chip: Winbond W25Q128JVSQ
by kenkaniffProduct Name: HP Pro x360 Fortis 11-inch G9
System BIOS: U94 Ver.01.08.00 10/06/2023
Serial Number: 5CG31946F5
SKU Number: 85W05EC#AK8
Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
I needed to remove bios password...-
by gsm4allhello, need help with bios unlocking
6050A3316601-MB-A01
2022-01-20
HP Elite x360 G830 G9 2-in-1...-
by Andrew BowerHi,
I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....-
- Loading...
