HP Stream 14-z011nd Bios
  • loonbg
    • Mar 2021
    Hey can some one share bios for HP Stream 14-z011nd or if it can fix mine.. laptop caps lock blink 2 times and there is no picture ( i check error codes and it look like bios is corrupted)
  • hoaca388
    Badcaps
    • Jan 2022
    • 12414
    Each forum has its own rules, you must comply with those rules.
    • FalconPunch
      Surface Pro X 1876 Bios corrupted
      by FalconPunch
      Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
      Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
      08-09-2025, 03:56 AM
    • zlr8r
      Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
      by zlr8r
      Greetings
      I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
      Serial Number: 5CG3202C16
      Product #/SKU: 739P0AV
      CT Number: PRTUE00WBI30YX
      Description: HP ZBook Firefly 14 inch G10
      BuildID: 23WWWGAZ602#SABU#DABU
      Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
      MAC address not found.
      • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
      10-28-2025, 01:56 PM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • TylerHyde21
      Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
      by TylerHyde21
      Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
      I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
      I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
      This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
      06-29-2024, 10:38 AM
    • Loli Popu
      DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
      by Loli Popu
      Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
      12-13-2024, 08:29 AM
