HP Clean VSS2 dumps,fix Endpoint Security error
  • Echoo
    • Apr 2018
    • 93
    • Budapest
    #41
    Hello!
    Which script should I use for 845 G7?
    Elitebook 845 G7
    SN: 5CG1312R7F
    ProdID: 8VZ06AV
      • 22415
      Originally posted by nistel
      Do anyone know the offsets for HP EliteOne 800 G4 Touch
      1962064 - 1987FFF fill with FF`s
        • 22415
        Originally posted by Echoo
        Hello!
        Elitebook 845 G7
        SN: 5CG1312R7F
        ProdID: 8VZ06AV
        1070048-1095FFF-25FB8.mps at post 1
        • Udemzy
          • May 2017
          • 168
          • Guatemala
          #44
          Hello pls can I get a script for 840 G6?
            • 22415
            Already done, see post 1
            • Udemzy
              • May 2017
              • 168
              • Guatemala
              #46
              Thanks,I'll check it out.
              • w.robx
                • Jul 2024
                • United Kingdom
                #47
                Models,Offsets and filesize:
                830 G7, 840 G7, 1030 G7. 18EA048-190FFFF-25FB8
                Script filename:
                18EA048-190FFFF-25FB8.mps
                Will this also work with the 850 G7?
                  • 22415
                  Yes, post #4
                  • enigmatech.id
                    • Aug 2021
                    • 5
                    • Indonesia
                    #49
                    635 aero g8, which one to use?
                      • 22415
                      Post #1 1070048-1095FFF-25FB8.mps
                      • enigmatech.id
                        • Aug 2021
                        • 5
                        • Indonesia
                        #51
                        just tried, the result is no change, both the .bak and .bin files are exactly the same
                          • 22415
                          They are the same, it`s already been cleared .
                          • enigmatech.id
                            • Aug 2021
                            • 5
                            • Indonesia
                            #53
                            Does that mean the method doesn't work for the 635 aero g8?
                              SMDFlea commented
                              Editing a comment
                              No, it just means that the problem is somewhere else.
                          • Verlengsnoer
                            • Sep 2016
                            • 110
                            • Netherlands
                            #54
                            Hi, i tryed the script for 640 g4,
                            Endpoint error has gone, but there is a warning
                            WARNING!! - Machine is not in commited state!
                            will that error be gone after fill in the dmi trough bcu, or did patching somehow failed?
                              SMDFlea commented
                              Editing a comment
                              Clean the ME firmware and/or use nbdmifit to commit or otherwise if its AMT or not.
                          • fr0n1k
                            • Feb 2020
                            • 13
                            • Russia
                            #55
                            Hi there, i have a problem. Ive got 445 g7 with password. I've removed it with RCunlocker. After that i got "hp endpoint security controller problem", and tryed to fight it with the help of script from this thread, but now i got "System is booting in Manufacturing Program mode", and i found no info that this should happen.. Is this normal? Where i can get SMBIOS UUID?
                              SMDFlea commented
                              Editing a comment
                              It is normal, use HP Bios Config to enter DMI.
                          • Karel Kubicek
                            • Jun 2024
                            • Czech
                            #56
                            Hello, i need to fix zbook 14u g6. Is it the same as 15u g6? Thanks
                              • 22415
                              I don`t know, why, do you have an endpoint error
                              • Karel Kubicek
                                • Jun 2024
                                • Czech
                                #58
                                yes exactly, sometimes after starting laptop, the end ponit error appear. In many cases, I just press ok and the system starts, sometime I have to close it, wait about 10 minutes and try to star again. It's very annoying. I appeared like 3 months ago after bios update. I tries to downgrade again but without success.
                                  • 22415
                                  i checked and you can use 18F4048-1919FFF-25FB8.mps at post #1 .You will need a bios backup.
                                  • nafienew
                                    • Aug 2014
                                    • 118
                                    • up
                                    #60
                                    Hello, thank you for sharing this wonderful file. I tried it on this device Hp probook x360 435 g8 and it did not work. Can you help?
                                    435 G8, 445 G8, 635 Aero G7, 635 Aero G8, 855 G7, 855 G8. 1070048-1095FFF-25FB8
