Lenovo Ideapad 300-17ISK Bios Needed
  • hobostove
    • May 2023
    • 73
    Board: NM-A941 or BMWD1
    Serial: PF0DNLX7
    Have a no display and fan spins/cycles every 15 seconds or so
    Tried clearing ME with fit, but no change. Not very confident I did that right though
  • volinakis
    • Jan 2021
    • 2877
    • N/A
    Serial: PF0DNLX7
    try
    • hobostove
      • May 2023
      • 73
      Worked perfectly, thank you volinakis!
      • volinakis
        • Jan 2021
        • 2877
        • N/A
        you are welcome
        • mkdj
          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
          by mkdj
          Dear all,
          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
          Here the steps I have taken to fix the laptop:
          - downloaded latest BIOS from Lenovo Website...
          10-18-2025, 03:43 AM
        • jendkkd jeje
          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
          by jendkkd jeje
          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
          10-11-2024, 03:12 PM
        • joven016
          Lenovo Ideapad S145 need working bios HELP!!
          by joven016
          Problem is blinking power led only
          i don't know exactly if it's s145-15igm or s145-14igm
          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
          Already tested some of posted bios here
          S145-14igm - success but invalid serial and not booting on OS
          S145-15igm - success with serial and some other info in bios but still not booting on OS
          already tried installing new windows but always booting on bios setup
          windows installer flash drive detected on...
          08-21-2025, 10:55 PM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • mximiliandz
          help bios lenovo ideapad s145-14iil type 81w6
          by mximiliandz
          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
          06-20-2025, 06:50 AM
