HP Omen 17-ck0010nl no video
  • DoOm86
    • Nov 2022
    • 42
    • italia
    I have the following notebook:
    HP Omen 17-ck0010nl
    SN: 5CD2018YV7
    MAINBOARD: DA0G3LMBCG0 REV G
    BIOS CHIP: WINBOND 25Q80DV16 2139 6124 52200
    The computer stop posting while whatching youtube. It turns on, stay on, it charghes the battery and turns off if i push the power button. I have all the necessary rails present, no shorts were found. Already disconnected everything from the mainboard and change the ram (trying even one per time in both slots).
    At this point i believe is a bios problem. I try with an usb pendrive and the bios on the HP site but it doens't work (i knew it but i still tried).
    I'm not expert of bios, i know since it's an intel i can't just flash the HP BIOS from the site into the bios chip. I'm about to make a reading of my current Bios and i'll save it, if needed i can upload it here.
    What shoud i do?
    Thnaks
  • peste
    • Dec 2016
    • 13258
    • ROMANIA
    HP Omen 17-ck0010nl
    SN: 5CD2018YV7
    What shoud i do?
    Thnaks
    Post the original bios of the laptop even if it is corrupted...
    • DoOm86
      • Nov 2022
      • 42
      • italia
      Ok, I couldn't read the chip with the clip that comes with the ch341. Tomorrow morning or Monday I'll desolder it and solder it on the adaptor. I hope the cheap reader won't give me hard time. Then I'll post it here.
      Maybe it's the ME region 🤷
        SMDFlea commented
        Editing a comment
        The 25Q80DV16 is not the bios chip
    • DoOm86
      • Nov 2022
      • 42
      • italia
      SMDFlea It's a winbond, it's start with the number of 25 and has 3,2v. But maybe you are right. I just checked the datasheet and take a screenshot. I'll check the mb better asap, probably i got tricked 🤦🏻
      • hoaca388
        Badcaps
        • Jan 2022
        • 12182
        Find which chip has the number 128 on it, for example: 25Q128DV.
        • DoOm86
          • Nov 2022
          • 42
          • italia
          OK, i found it. it's a "mxic 25u1633f".
          It doesn't have "128" in it but it is the only chip that according to the datashhet is a bios chip.
          This notebook has also another chip close to the SIO (IT5570e-256 CXA) which is still a ITE (8308fn CXA). Never seen something like this.
          I backuped the bios (hoping is this one mxic 25u1633f😆) and posted it here
          • volinakis
            • Jan 2021
            • 2824
            • N/A
            red square
            • DoOm86
              • Nov 2022
              • 42
              • italia
              volinakis The chip in the red square is the pic with the ic "mxic mx 77L12850F" . I took some other pics of ic on the board.
              The ic "mxic 25u1633f" that I upload the bin file previously it was close to the cpu, under the black plastic tape.
              Don't tell me I backed up the wotng bios 😅 according to the datasheet the "mxic 25u1633f" is a bios ic. The "mxic mx 77L12850F" in the red square doesn't have the "25" or "24" at the beginning like the usual bios chip has.
              ​​​​​Obviously there are many things I don't know about ic bios 😅
              Anyway if the "mxic mx 77L12850F" is the bios chip, tomorrow I can upload here the bin file.
              Thanks 🙏🏻
              • volinakis
                • Jan 2021
                • 2824
                • N/A
                Thanks 🙏🏻
                not "if", THAT'S bios chipset.
                • DoOm86
                  • Nov 2022
                  • 42
                  • italia
                  Ok, tomorrow I'll try to back it up and post it here, hoping my cheap bios programmer will do the job (ch341).
                  Thanks for the help till now, I really appreciate it
                  • volinakis
                    • Jan 2021
                    • 2824
                    • N/A
                    use AsProgrammer as software for CH341A
                    • DoOm86
                      • Nov 2022
                      • 42
                      • italia
                      I succeded to save the bios with the AsProgrammer. i lefted the setting as they were (size=16777216; Page=256; SPI=25xx).
                      Thanks in advance guys
                      • volinakis
                        • Jan 2021
                        • 2824
                        • N/A
                        try
                        • DoOm86
                          • Nov 2022
                          • 42
                          • italia
                          Same thing. It turns on, stay on, it charghes the battery and turns off if i push the power button. I have all the necessary rails present, no shorts were found. The display is completly dark (no image, no backlight) and nothing with an external monitor. I cecked again the pin of the bios with the oscilloscope and i have both voltages and signal presents.
                          Can we try a different bin or we are sure that is not the problem at this point?
                          Thx
                          • volinakis
                            • Jan 2021
                            • 2824
                            • N/A
                            Thx
                            that's the only one extracted from bios update.
                            • DoOm86
                              • Nov 2022
                              • 42
                              • italia
                              OK then. I'll try to check the entire board again and see what i can do more to try to understand what the problem could be. i'll write here when i have updates
                              • DoOm86
                                • Nov 2022
                                • 42
                                • italia
                                Update: after making many many attempts and checked everything, I belive the GPU has failed (but not shorted). I sent the laptop to HP which replace the mainboard. Now it's working perfectly. I checked the values of the new mainboard and confronted them with the old one. On the GPU coil the ohms value was higher on the new motherboard, that's all.
                                Hope this can help someone else in the future.
                                Thanks everyone for the help.
                                • JoWed
                                  Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                  by JoWed
                                  Hello Community,
                                  I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                  07-01-2025, 09:32 AM
                                • Dani Rahal
                                  hp omen 17-cb0247ng bios
                                  by Dani Rahal
                                  Hi can some one help me plz
                                  i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
                                  i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
                                  the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
                                  i have the orginal bios if some one can see what the problem or...
                                  05-30-2025, 09:11 AM
                                • Blur3195
                                  HP Omen 16-u0000sl. bios
                                  by Blur3195
                                  Hi, I have a problem with my HP Omen 16-u0000sl.
                                  I have a corrupted dump from which I extracted the DMI and inserted it into a stock BIOS. With the corrupted dump, the Caps Lock light blinks twice normally and twice quickly (BIOS corrupted). With the stock BIOS plus the DMI, the laptop starts a series of reboots but never initializes. I would be very grateful if someone could help me; I think maybe the DMI area is corrupted....
                                  08-22-2025, 11:24 AM
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
                                • zerbatin
                                  HP Omen 16-c0825no BIOS.
                                  by zerbatin
                                  I have problem with my laptop. When I turn it on it do not POST. Black screen with FAN not working, When pressing CTRL+V/B I can go into BIOS update, but after auto restart there is no update screen. Nothing happen.
                                  I have tried using this DUMP but with no go,
                                  https://www.badcaps.net/forum/troubl...os#post3210916
                                  My winbond BIOS chip got fried as well after 4th attempt, now it is unsoldered and I am waiting for...
                                  07-17-2025, 02:14 PM
