Thinkpad P15 G1 (Type 20ST-CT01WW)
  • badcappo
    • Jun 2018
    • 20
    Part number seems to be: 5B20Z25503
    Thanks for any help :-)
    • 22279
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
    • akwky
      by akwky
      Hi!
      04-14-2025, 01:56 PM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • iizik
      P15 Gen 1 (type 20ST, 20SU) Laptop (ThinkPad) - Type 20ST need main and video BIOS
      by iizik
      P15 Gen 1 (type 20ST, 20SU) Laptop (ThinkPad) - Type 20ST needs the main BIOS and video. The client says that after the Windows updates there was a firmware update and after that the device makes the sound of music when there is no screen. Moreover, if you turn it on several times then the picture sometimes appears and it works and passes all tests (wonder)
      and may even reboot normally a couple of times
      Now he doesn't want it anymore, no matter what I tried
      It helped to change the video cable a couple of times, I ordered a new cable, it didn't help
      Of course I checked the...
      07-17-2024, 09:58 AM
    • 1g0r
      Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
      by 1g0r
      First, the data in brief:
      Manufacturer: Lenovo
      Model: ThinkPad L15 G3 21C3-0016GE
      motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
      IC Bios 1: MX77L25650F
      IC Bios 2​: MX25L25673G
      EC Chip: NPCX997KAABX
      So far I've been a silent reader, but now I need your help
      I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
      I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
      The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
      01-18-2025, 02:39 AM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
