Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
  • Joluvillas
    • Jun 2024
    • 9
    • The United States of America
    Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple of questions I hope someone can answer so I can try and save my laptop.
    1- Is there a way the motherboard or chip might get damaged by using the clip on the CH341a (modded to 3.3v) instead of desoldering the chip? Like a short or something that may have broken the laptop? I was very creful on the order of the connection.
    2- I am attaching a picture of the board for location purposes, and a close up of sorts of the EC chip (winbond 25Q80DVSIG) I extracted the .bin file from (And then attempted to get it back in) and also a close up of the other chip I was told is containing the main bios. Can someone please confirm if I got the correct main bios chip this time? I haven't touched it yet, since the clip does not fit that particular chip (GD25B256DYIG)
    3- Going back to the main bios chip, if it is indeed the GD25B256DYIG, is the only way to read it desoldering it? also, will the CH341a read it once I desolder it with the adapter I attach in another picture below?
    I just don't want to mess up further so I am reaching out to you awesome people for guidance. I leave the info on the machine below:
    Model: Lenovo ThinkPad L15 20U4 (Gen 1)
    S/N: PF3PXX6F
    Type: 20U4
    Machine Type: 20U4S8GY00
    Motherboard: GL4A0/GL4A0 NM-C632
    Processor: 1x 10th Generation Intel® Core™ i7-10510U Processor(Core i7-10510U)
    I also uploaded the .bin file I got from the EC chip, but I think it's mostly FFFF's
    Thank you very much in advance for any attention given to this humble post, I hope it attract's someone's attention and we can work this out together!
  • Markus1741
    • Sep 2020
    • 964
    • N/A
    I'm trying to explain, keep your hands off the chips, it won't help you read them.
    Lenovo does not store the BIOS password in the BIOS chip but in the EC chip, which you cannot read.
    For most Lenovo notebooks with a BIOS size of more than 33MB, it no longer works to manipulate the BIOS.
    Member Maxpower3 has found a way and also published how to interrupt the communication between EC and BIOS at startup.
    I was able to unlock a 2022 Lenovo T14s Gen2 with this trick.
    Watch YouTube video from his channel.​
    https://www.youtube.com/watch?v=hK8IIi_Hlh8
    https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
    • Joluvillas
      • Jun 2024
      • 9
      I found this forum way too late, I am learning from scratch, I already messed up with the chip, but I will watch this video and see if I can do it, thank you for replying and I will post if successful.
      PostEdit: The laptop doesn't even turn on after I flashed that 1mb file back into the chip, any ideas as to how I can bring it back the way it was before so I can work with the steps Maxpower3 left for us and try to bypass it? Thanks in advance for any kind of help-
      • Markus1741
        • Sep 2020
        • 964
        • N/A
        What comes to mind is that you damaged resistors while programming the chip, just load a picture.
        This could cause it to no longer start.
        • Joluvillas
          • Jun 2024
          • 9
          Hello there, thanks for following up, I found a great tutorial on yt and was able to verify that there no shorts on the motherboard, I checked everything from the adapter power input jack, coils, capacitors around the chips, the bios chip is reading 3.3v in pin 8 ( VCC As indicated in the video) I followed the tutorial to the letter (Actually I checked out 3 different videos on how to troubleshoot a dead laptop motherboard) and everything checks out, in the video it is mentioned that if Bios chip reads 3.3v on pin 8, to look for the right bios file and flash it. That would be my next step, since the 1,024kb file I extracted from that chip is not working when I flash it back, still dead board.
          What troubles me is, that the file is 1,024kb and I can't find it anywhere. All the bios posted here and everywhere are at lease 16mb (8mb when compressed) and I don't think that's what I need, can you tell me the name of the file I should be looking for? is it a part of the whole bios I have to extract maybe with a hex editor? Any clue will be highly appreciated
          Thank you btw for the help, as soon as I am able to power it up, I will try the method Maxpower3 shared.
          PostEdit: I can still upload some pictures of the mainboard if you need me to, but my camera isn't that good. But if it would help, I can try to load it in parts maybe
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • thxd43
            Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
            by thxd43
            Hello, first of all, excuse me, I am using the translator, English is not my native language.
            I have a Lenovo ideapad 330S - 14IKB laptop.
            The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
            02-23-2023, 08:37 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
