Microsoft Pro 9 2038 BIOS Password
    Hello, can someone try to unlock this file for me, but please dont delete DMI data. I will also try to unlock, If I succed I will post it here. Thanks in advance!
    Serial number: 0F00D1323163BF
    Send to you, try
      Thanks a lot, but I already managed to unlock and I assembled device, here is my unlocked file
        Hello please can you tell me where is the location of the bios ic on the surface pro 9 thanks.
          It is on bottom side, you will need to remove motherboard from device
            Thank you very much for your information, I will have a look on the other side, excellent.
              Hello, do you know if the bios from a surface Pro 9 i5 will work on the surface pro9 i7 version? Thanks
                Its your own bios that should be unlocked,don`t flash the bios from another laptop. Post your backup and the laptop serial number. Don`t erase the chip unless you`re sure your backup is good.
                  Hello, thanks for your reply, well you see I think I might have a corrupted bios because when I power on the surface pro 9 I get the windows logo comes on twice and then it turns off. I have tested.3v and 5 v are good, what can I look for next, thanks
                    Can someone please unlock password on this bios bin file for surface 9 2038?or explain how to unlock it?Thanks in advance
                    Surface Pro 9 - i7/16/256
                    Device Serial Number: 0F00MGH23073BF
                      Unlocked
                      Become a Badcaps supporter
                      Thanks to all supporters.
                        Hello, Would you please clean ME for me
                        Surface Pro 9 - i7/32/1TB
                        Device Serial Number: 0F00KYV23213BF
                        thanks a lot
                          thanks a lot
                          It's not opening in FITC, is your file correct or its not copied properly.
                            thanks for your answer
                            i have problem with 16 versions of me regions too
                            i cant fix 16 versions
                            i had read a correct surface pro 9 bios and i cant fix with FIT
                            do you want send that file too?
                              @SMed Can you help why its not able decomp in FITC tool, any modification ??
                                its me region version
                                  hello
                                  no way to clear this bios?
                                    hello
                                    me cleaned
Name:	Screen Shot 2025-03-16 at 12.02.21.png
                                      Originally posted by volinakis View Post
                                      me cleaned
                                      thanks a lot dear
                                      i will check and let you know
                                        me cleaned
                                        it doesn't work
                                        thanks for your help
