Microsoft Pro 9 2038 BIOS Password
  • sonic_electronic011
    • Feb 2018
    • 7
    • Srbija
    Hello, can someone try to unlock this file for me, but please dont delete DMI data. I will also try to unlock, If I succed I will post it here. Thanks in advance!
    Serial number: 0F00D1323163BF
  • minhdigital
    • Nov 2022
    • 758
    • Vietnam
    Send to you, try
      • Feb 2018
      • 7
      • Srbija
      Thanks a lot, but I already managed to unlock and I assembled device, here is my unlocked file
      • Amir sagharchi
        • Feb 2023
        • 6
        Hello please can you tell me where is the location of the bios ic on the surface pro 9 thanks.
          • Feb 2018
          • 7
          • Srbija
          It is on bottom side, you will need to remove motherboard from device
          • Amir sagharchi
            • Feb 2023
            • 6
            Thank you very much for your information, I will have a look on the other side, excellent.
            • Amir sagharchi
              • Feb 2023
              • 6
              Hello, do you know if the bios from a surface Pro 9 i5 will work on the surface pro9 i7 version? Thanks
                • 21100
                Its your own bios that should be unlocked,don`t flash the bios from another laptop. Post your backup and the laptop serial number. Don`t erase the chip unless you`re sure your backup is good.
                • Amir sagharchi
                  • Feb 2023
                  • 6
                  Hello, thanks for your reply, well you see I think I might have a corrupted bios because when I power on the surface pro 9 I get the windows logo comes on twice and then it turns off. I have tested.3v and 5 v are good, what can I look for next, thanks
                  • armands0212@gmail.com
                    • Oct 2021
                    • 28
                    • Latvia
                    Can someone please unlock password on this bios bin file for surface 9 2038?or explain how to unlock it?Thanks in advance
                    Surface Pro 9 - i7/16/256
                    Device Serial Number: 0F00MGH23073BF​
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11861
                      Unlocked
                      • payam
                        • Nov 2015
                        • 79
                        • iran
                        Hello, Would you please clean ME for me
                        Surface Pro 9 - i7/32/1TB
                        Device Serial Number: 0F00KYV23213BF
                        thanks a lot
                        • Bios Cracker
                          • Oct 2024
                          • 315
                          • India
                          thanks a lot
                          It's not opening in FITC, is your file correct or its not copied properly.
                          • payam
                            • Nov 2015
                            • 79
                            • iran
                            thanks for your answer
                            i have problem with 16 versions of me regions too
                            i cant fix 16 versions
                            i had read a correct surface pro 9 bios and i cant fix with FIT
                            do you want send that file too?
                            • Bios Cracker
                              • Oct 2024
                              • 315
                              • India
                              @SMed Can you help why its not able decomp in FITC tool, any modification ??
                              • payam
                                • Nov 2015
                                • 79
                                • iran
                                its me region version
                                • payam
                                  • Nov 2015
                                  • 79
                                  • iran
                                  hello
                                  no way to clear this bios?
                                  • volinakis
                                    • Jan 2021
                                    • 2743
                                    • N/A
                                    hello
                                    me cleaned
Name:	Screen Shot 2025-03-16 at 12.02.21.png
                                    • payam
                                      • Nov 2015
                                      • 79
                                      • iran
                                      Originally posted by volinakis
                                      me cleaned
                                      thanks a lot dear
                                      i will check and let you know
                                      • payam
                                        • Nov 2015
                                        • 79
                                        • iran
                                        me cleaned
                                        it doesn't work
                                        thanks for your help
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • BlackVisor
                                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                          by BlackVisor
                                          RedmiBook Pro 1542022 6800H
                                          SKU: TM2113-39463
                                          Model Number: RMA2204-AB
                                          CMIIT ID: 2022AP1835
                                          SN: 39463/22WD01355
                                          BIOS version: RMARB5B0P1010 20230628
                                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                          01-14-2024, 06:35 AM
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
