Asus K52JK SX092X - Bios request
  • odtech
    • Jul 2023
    • 52
    • South Africa
    So I have this ASUS K52JK which cpu overheats seconds after power on even while idling at the bios menu. The laptop works although it does throttle the cpu.
    I was attempting to clean the bios and accidentally lost my original bios dump.K52JR found on badcaps does work but has the same issue with cpu overheating.
    Can anyone post a bios dump for this laptop?
    Edit
    Laptop: ASUS K52JK
    Mainboard: K52JR Rev2.0
    Radeon GPU 1Gig
    S/N: A4N0AS44636916C
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
  • cr4zychriss
    by cr4zychriss
    • Rebrand: PC Specialist
    11-14-2025, 04:04 PM
