HP 15s-eq1096AU BIOS REQUEST
  • rotceh_dnih
    • Jun 2020
    • 43
    HI
    I have a HP 15s-eq1096AU with a failed bios
    I found a HP exe that allowed me to pull the bin and i entered my key in @8000-8030 & serial @00-FF
    This booted to a screen saying clearing bios block 0-630 then restarted to blinking caplocks key reporting broken bios again
    If anyone could make me a bios with the DMA info etc from this dump that would be greatly appreciated
    • 22119
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • rotceh_dnih
      • Jun 2020
      • 43
      my apologies
      Customer no longer has the box but these are all the numbers from the back
      Model: 15s-eq1096AU
      S/N# 5CD1097XFK
      ProdID 1G6V2PA#ABG
      XU100282-19102
      R-R-hpk-TPN-Q230
      R-C-INT-AX200NGW
      Mainboard model : DAOP5MB26A0 REV:A
      Many thanks
      • hoaca388
        Badcaps
        • Jan 2022
        • 12420
        Originally posted by rotceh_dnih
        my apologies
        Model: 15s-eq1096AU
        S/N# 5CD1097XFK
        ProdID 1G6V2PA#ABG
        XU100282-19102
        R-R-hpk-TPN-Q230
        R-C-INT-AX200NGW
        Many thanks
        HP Laptop - 15s-eq1096tu
        • rotceh_dnih
          • Jun 2020
          • 43
          Still flashing caps lock - 5 long 3 short
          Many thanks though appreciate the help
            SMDFlea commented
            Editing a comment
            check for loose ram slot pins
        • hoaca388
          Badcaps
          • Jan 2022
          • 12420
          Check hardware , this is an origin bios.
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • hotcrossedbuns999
            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
            by hotcrossedbuns999
            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
            3. I could only locate two chips that look like bios chips. Could someone verify this
            01-03-2025, 12:32 PM
