BIOS for Asus ROG G713PV
  • shiyab
    • Sep 2023
    • 1482
    • india
    Originally posted by lavie
    HVE GOTTEN THE SERIAL NUMBER R3NRKD007389129
    hi try this new file
    • lavie
      • Aug 2015
      • 88
      • southafrica
      THNK WORKS
      • Vmalpica01
        • Oct 2020
        • 27
        • Colombia
        Hi guys, I confirm that the luzvel64 bin works, however it doesn't have DMI information.
        Without the DMI information Windows Update doesn't download the updates. I can confirm this because I have a computer working at the moment and until I modified the DMI information Windows Update didn't work.
        I copied the information from block 100FFF0 to 1011BAF.​
        • futadmytro
          • Aug 2020
          • 60
          • Сполучені Штати
          Solved!!!
          I flash
          32MB_NEW.zip​ and gpu works!!!
          so if you will flash G713PV bios to g713pi laptop (mb model is the same) GPU driver wil not install
          • MajorJava
            • Mar 2025
            • 4
            Hi all - First timer here and I"m trying to reflash a dead Asus G713PV-WS94. The serial is R4NRKD01821217C
            Can I just use the .bin file that somebody else uploaded in this thread earlier? I understand about DMI information where I need to program in my SN, MAC address, and that windows GUID number. But I guess I'm wondering if I can just flash using the above bin file, boot it up on Linux and set my DMI info after I can get it booted? Or do I have to hexedit the bin file and add those bits in first?
            Also, as I am learning more about this, I asked chatgpt about some of this stuff and it keeps telling me that the bios needs an ME section and I even used an ME Analyzer tool on that previously uploaded bin file and it doesnt have the ME section. It claims that the bios likely won't boot without ME. Is that false information from chatgpt?
            I'll keep reading more but if someone can get me a BIOS file that will work for me, I'd appreciate it greatly!
            Thanks...
            • peste
              • Dec 2016
              • 12852
              • ROMANIA
              #26
              post motherboard model,etc.
              post the contents of the bios chip even if it is corrupted..
              • MajorJava
                • Mar 2025
                • 4
                The sticker on the inside of the case shows:
                G713RX-2F
                6070B2005222
                Rev: 1.00 A01
                HSF:HF
                Date Code: 952344
                I can't get a dump of the original bios chip because it got damaged when I had to remove it from the board. It seemed to have some sort of adhesive keeping it stuck down to the board. I used a board warmer, lots of flux and hot air. There seemed to be a black material underneath it which I think had to be adhesive. Can you still do anything for me even without the original dump?
                Thanks so much for helping me!!
                • peste
                  • Dec 2016
                  • 12852
                  • ROMANIA
                  #28
                  G713RX-2F
                  6070B2005222
                  Rev: 1.00 A01
                  HSF:HF
                  Date Code: 952344
                  try post #13..
                  • MajorJava
                    • Mar 2025
                    • 4
                    Peste - Thank you so much for telling me to use post #13! It worked!!! It is very late here now so I will continue tomorrow but I need to remove the heat pipe mechanism and put new thermal paste everywhere that it is suppose to go. I then have to find the instructions on setting up the SN, macaddress, and GUID. I noticed that the serial was defaulted to something like 123456789. I will have to prepare a bootable USB thumb drive and load the tools I need to write to the DMI.
                    Thanks again for watching this forum and helping me out! What a great forum. I will send in a donation tomorrow to keep it running.
                    • mdkfdgod
                      • Jun 2022
                      • 5
                      • iraq
                      #30
                      hello everyone
                      I am looking for help with the bios Asus ROG G713P does not give video
                      G713pI-XS96
                      SN R2NRKD020595087
                      • peste
                        • Dec 2016
                        • 12852
                        • ROMANIA
                        #31
                        Originally posted by mdkfdgod
                        hello everyone
                        G713pI-XS96
                        SN R2NRKD020595087
                        • mdkfdgod
                          • Jun 2022
                          • 5
                          • iraq
                          #32
                          this is the corrupted bios my friend
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11786
                            #33
                            G713PI
                            • mdkfdgod
                              • Jun 2022
                              • 5
                              • iraq
                              #34
                              Originally posted by hoaca388
                              G713PI
                              thank you for replay
                              but no display also 😥😥
                              this time cpu not heating
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11786
                                #35
                                CPU is dead.
                                • mdkfdgod
                                  • Jun 2022
                                  • 5
                                  • iraq
                                  #36
                                  CPU is dead.
                                  it couse when bios update
                                    • 20966
                                    post pictures of the QR codes or barcode stickers on the motherboard.
                                    • mdkfdgod
                                      • Jun 2022
                                      • 5
                                      • iraq
                                      #38
                                        • 20966
                                        • donnietr
                                          • Jul 2025
                                          • 5
                                          Hello all,
                                          I have a G713PV-WS94
                                          SN: S5NRKD038081196
                                          I just bought this from ebay. Has power light but doesnt post or turn on backlights on keys.
                                          I used the #13 bios but looking back i dont think they are the same types of laptops.
                                          I downloaded the file from asus for mine i guess. Had ,334 at end. I havent written it yet because of the question about the bios chip.
                                          You were talking about an mx77u2560fz4141 32 mb chip.
                                          Mine is a windbond 25r256jweq.
                                          Is it this one or a windbond 25q80dvsig?
                                          Hope these help. need help for sure. will try tomorrow to install the .334 version.
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • caglarec2268
                                            Asus X515EA Bios File Please
                                            by caglarec2268
                                            merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                            Now "please follow the steps below to recover your bios" text remains on the screen
                                            I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                            laptop model x515ea-bq945w
                                            s/n: R4N0CV02K527148
                                            CN:HWFB
                                            Board model; ASUS X415EA R7.0
                                            bios chip: GD25Q128...
                                            11-27-2024, 03:51 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • wakethesleep1111
                                            Bios File Needed for asus tuf15
                                            by wakethesleep1111
                                            Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                                            05-27-2025, 10:56 PM
