Which software for GD25LB128 with CH341a
  • Squaryhead
    • Apr 2024
    • 9
    • Belgium
    I'm struggling to find a software to reconfigure a GD 25LB128 chip with a CH341 A.
    Do you know any ?
    Thanks !
  • peste
    • Dec 2016
    • 13793
    • ROMANIA
    Do you know any ?
    Thanks !
    try these two, if they don't work, select something similar from the database.
    https://www.badcaps.net/forum/showpo...6&postcount=10
    https://www.badcaps.net/forum/showpo...04&postcount=7
    • Squaryhead
      • Apr 2024
      • 9
      • Belgium
      Thanks !!! https://www.badcaps.net/forum/showpo...04&postcount=7 is working !
      Now I just have to find a backup BIOS
      Thank you !!
      • md500
        [Question] Ch341a and 5v to 3.3v with logic converter
        by md500
        zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
        Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
        What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
        I can't buy the ch341a 1.6v that has...
        05-24-2024, 06:51 PM
        How to add chip support to NeoProgrammer software for the CH341A Programmer
        by SMDFlea
        Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
        and once you do find them there`s a few crucial steps missing.
        Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
        Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
        After adding the chip save the xml file and copy it to the root directory of the...
        05-26-2024, 07:15 AM
      • 74kieran
        CH341A software
        by 74kieran
        What software is best for the CH341A programmer. I am trying to flash a 25Q128jvpq chip.
        12-27-2021, 02:00 PM
        Copy DMI info easily with Hex editing software and Macro script
        by SMDFlea
        Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
        Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
        02-28-2023, 02:14 PM
      • Sparklingx
        CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
        by Sparklingx
        So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
        So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
        now all...
        08-29-2024, 01:53 PM
