CH341A software
  • 74kieran
    • Dec 2021
    • 33
    • Uk
    CH341A software
    What software is best for the CH341A programmer. I am trying to flash a 25Q128jvpq chip.
  • JuanL
    • Dec 2021
    • 14
    • Spain
    Re: CH341A software
    According the descrition on the next webpage, 25 SPI series chips should be recognized automatically.." https://www.openhacks.com/page/produ...r#.YctUN2iZMuU
    Also have a look here: https://winraid.level1techs.com/t/he...greement/34028
      • 21845
      Re: CH341A software
      It will only fully recognize the ones that are in the support list. NeoProgrammer, Colibri,ASProgrammer and Flashrom are all good alternatives to the provided software, and theres support for more chips.
      • usyusy
        • Sep 2021
        • 171
        • Pakistan
        Re: CH341A software
        sir which one is the best of these.
          • 21845
          Re: CH341A software
          try them all and pick your favourite
          • usyusy
            • Sep 2021
            • 171
            • Pakistan
            Re: CH341A software
            • filippok
              • May 2012
              • 21
              • Greece
              Re: CH341A software
              Hi to all, i just read e 25q128fv chip from dell 5567 using, colibri 1.0.1.61, NeoProgrammer 2.2.0.10 and CH3441a 1.29 and then i compare the files with HxD.
              For the first 2 files bin the files are the same but comparing them with the file created with CH3441a 1.29v both of them are different.
              How that is going on? And how i could be sure which file is correct?
                • 21845
                Re: CH341A software
                colibri, NeoProgrammer ,ASProgrammer and flashrom are the most reliable software
                • vinceroger69
                  TL866CS MiniPro EPROM programmer software
                  by vinceroger69
                  Hi has anyone got the latest software for the TL866CS MiniPro EPROM programmer version 03.2.86 is installed now i have tried the update site in the programmer software but it wont connect to their website i am running windows 10
                  Edit found this site programmer works now http://www.xgecu.com/EN/Index.html
                  09-03-2024, 06:21 AM
                • testaccgta
                  Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                  by testaccgta
                  Hi, everyone!
                  I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                  I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                  09-01-2024, 08:24 PM
                • ugamazing
                  Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                  by ugamazing
                  I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                  08-31-2022, 07:34 AM
                  Common SPI bios chip programming Questions and Answers
                  by SMDFlea
                  Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                  A: If you can`t read from it how do you expect to write to it ?.
                  Q: Why is my bios chip unreadable ?.
                  A: The programmer is faulty or has a worn or broken zif socket.
                  The USB cable is frayed,connector pins worn or some other physical damage.
                  Not enough amperage or voltage to power the programmer properly.
                  Bad...
                  09-02-2021, 04:40 PM
                • what_1282105
                  Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                  by what_1282105
                  Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                  02-14-2025, 07:27 PM
