unlock BIOS unowhy Y13 2021
  • mafd007
    • Apr 2022
    • 3
    • Algeria
    #61
    Hello! I need bios for my unowhy y13 laptop
    serial: IFP136109481
    Production year: August 2021
    thank you.
    • peste
      • Dec 2016
      • 13678
      • ROMANIA
      #62
      thank you.
      post the contents of the bios chip even if it is corrupted..
      • mafd007
        • Apr 2022
        • 3
        • Algeria
        #63
        Hi! Thank you! I will send it as soon as possible.
        Is it essential to send the serial number? I mean , is it possible to make it work with the same bios of August 2021 production year?
        • bensoftchlef
          • Jun 2024
          • 14
          • algeria
          #64
          Please i need unlock BIOS unowhy Y13G011S4EI
          Production year : Juillet 2021
          Serial IFP129035415
          • peste
            • Dec 2016
            • 13678
            • ROMANIA
            #65
            Serial IFP129035415
            try..
            • hoaca388
              Badcaps
              • Jan 2022
              • 12354
              #66
              Serial IFP129035415
              Unlocked
              • bensoftchlef
                • Jun 2024
                • 14
                • algeria
                #67
                Originally posted by hoaca388
                Unlocked
                thanxxxxxxxx
                • Sakihouse
                  • Dec 2022
                  • 36
                  • Côte d'Ivoire
                  #68
                  Kindly unlock BIOS unowhy Y13G011S4EI
                  Production JUILLET 2021
                  Serial IFP1300071588
                  EM_IG116_2008_ENE_F_V1.0
                  Thks...
                  • volinakis
                    • Jan 2021
                    • 2874
                    • N/A
                    #69
                    Thks...
                    try
                    • BRAHIIM07
                      • Jan 2024
                      • 4
                      • ALGERIA
                      #70
                      Production year : aout 2021
                      Serial IFP134092399
                      v1.0
                      • peste
                        • Dec 2016
                        • 13678
                        • ROMANIA
                        #71
                        Serial IFP134092399
                        v1.0
                        try..
                        • BRAHIIM07
                          • Jan 2024
                          • 4
                          • ALGERIA
                          #72
                          It's work good thank's for your help sir
                          • bejaoui
                            • Feb 2017
                            • 64
                            • ariana
                            #73
                            Production year : Aout 2021
                            n:IFP131043555
                            THINKS
                            • peste
                              • Dec 2016
                              • 13678
                              • ROMANIA
                              #74
                              n:IFP131043555
                              THINKS
                              the bios posted is almost empty..read the chip and post again..
                              The bios chip must be unsoldered from the board before writing or reading..
                              do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                              solder wires between the programmer and the bios chip..
                              you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                              • bejaoui
                                • Feb 2017
                                • 64
                                • ariana
                                #75
                                OK THINK YOU
                                • bejaoui
                                  • Feb 2017
                                  • 64
                                  • ariana
                                  #76
                                  serial: IFP131043555
                                  Production year: Augu 2021
                                  bord: EM_IG116_200B_ENE_F_V1.0
                                  lost bios dump
                                  thanks you very much
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • Akhlz001
                                    by Akhlz001
                                    09-20-2025, 07:15 PM
                                  • pirati
                                    by pirati
                                    10-27-2025, 04:20 PM
                                  • salim5566
                                    loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                    by salim5566
                                    Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                    06-26-2025, 03:25 PM
