Request for BIOS bin file - Dell Inspiron 14-5448
  • Felipe_Serra_83
    • Nov 2023
    • 25
    • Chile
    As the title says. For programming with CH341a MiniProgrammer
    ​Thanks all!
    • 22279
    Post the laptop service tag and your bios backup - https://www.badcaps.net/forum/troubl...before-posting
    • Felipe_Serra_83
      • Nov 2023
      • 25
      • Chile
      Missed that... Sorry.
      Checked the "BIOS guides, methods, resources and tools".
      Went to the Dell website to look for the BIOS file. Got an .exe, which I can't use (I'm on Linux)
      The chip is a Winbond, 25Q64FVSIQ. Got the .bin file from the IC using the CH341a programmer.
      Made two copies of the file, verified both using md5sum command. I attached both files below.
      Service Tag for the laptop: 6684L22
      Model: Dell Inspiron 14-5448
      Board model number: LA-B015P
      Problem with the computer: laptop starts, blank screen. Fan spins for a few secs, then stops. Laptop continues working, CPU and GPU get hot. Intermittent single beeping comeing out of the speakers.
      More details of the problem here: https://www.badcaps.net/forum/troubl...-keeps-running
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • danielgagcia
        Bios inspiron p69g dell inspiron starlord13 b 152641 stuck in dell logo
        by danielgagcia
        Hi i need this bios it stuck in dell logo can help me
        MB: starlord13 b 152641
        SN: 5F50ZB2...
        11-13-2025, 05:25 PM
      • sahamipoor
        need bios dell Inspiron 17 7000 2-in-1 p42e
        by sahamipoor
        hi...
        i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
        i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
        i updated to latest version and try other version but not working!
        service tag: HCQ3JW2
        i need your kind....
        10-01-2025, 11:10 AM
      • shugu1701
        dell inspiron 15 7510 bios
        by shugu1701
        Hello, i have a dell inspiron 15 7510 g48c0$la was not turning on at all and i couldnt find the right bios but with a bios for almost the same model it turn on, cpu warm up fan spin but no picture, so i gess if someone can repair my bios it should be fine.
        spec: dell inspiron 15 7510 g48c0$la
        servicetag 6p70dl3
        reg type p106f002
        i link the original bios
        thank you...
        11-06-2024, 07:45 AM
