BIOS HP Stream Laptop 14-ax113la
  • karlox
    • Dec 2017
    • 138
    • México
    Good morning, can someone share with me a copy of a working BIOS for this computer? I downloaded them from the hp page, but it is not working for me, I attach a copy of the backup of this card. The worst thing is that it's working for me, I have a suspicion that I'll have to program the EC, the motherboard license plate is DA0P9MB26A0 REV. A
    Computer Data Under Repair
    HP Stream 14-ax113la
    MB DA0P9MB26A0 Rev. A
    SN# 5CD1495JDV
    Celero N4020
    The team went into the workshop because it didn't detect the battery, an error was found in a AON6380 mosfet and a RT9610CGQW, they were replaced shortly, but now the equipment gives me a starting error, it already recognizes the battery but I don't have an image.
    attached copy of my Bios image
    hp 14-ax113la_25B64CSIG.zip
    • 22283
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • karlox
      • Dec 2017
      • 138
      • México
      You MUST:
      Thanks, I've already corrected my mistake. I'm sorry, I'll be more attentive to the rules
      • Bloodhoundje
        by Bloodhoundje
        03-16-2024, 03:12 PM
      • JoWed
        Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
        by JoWed
        Hello Community,
        I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
        07-01-2025, 09:32 AM
      • thxd43
        Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
        by thxd43
        Hello, first of all, excuse me, I am using the translator, English is not my native language.
        I have a Lenovo ideapad 330S - 14IKB laptop.
        The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
        02-23-2023, 08:37 PM
      • legendkray
        BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
        by legendkray
        I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
        07-05-2025, 09:25 AM
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
