Asus N55SL total dead after BIOS flash
  • grahamw01
    • 256
    I have an Asus N55SL that crashed during a BIOS flash in Windows, and now it is dead to the world.
    I have repaired a few laptops that have experienced this using BIOS recovery methods that can be accessed by a certain key combination when plugging the power socket in.
    However these have required the laptop to still actually turn on, show any sign of life with a fan spinning etc.. but this laptop does nothing anymore. No fans, no lights, no sounds, not even a charging light to indicate the battery is chairing when the AC is plugged in.
    The key combination for BIOS recovery on this machine is apparently CTRL + HOME, but absolutely no signs of life from this machine.
    Can anyone please recommend something? Nothing else had happened to the machine other than a failed BIOS flash.
    Kind Regards,
    Graham
  • sorinac
    • Jul 2013
    • 123
    • Romania
    Re: Asus N55SL total dead after BIOS flash
    only solution is to take out the spi flash chip and use a programer to program it, or buy a preprogramed chip.
    • grahamw01
      • 256
      thanks for your reply, what is the spi chip? could you please help me identify it?
      Graham
      • sorinac
        • Jul 2013
        • 123
        • Romania
        u will need a programing tool for it and a software. and also the bios file
        good luck.
        I have attached bios (spi) chip location and the bios file
        • grahamw01
          • 256
          good luck.
          Wow thank you very much! Do you know what model the chip is? Someone at my work has a programming tool and programs lots of eeprom chips, would the same software be okay?
          For the bios file does it just require the .204 file or does something need to be extracted?
          Kind Regards,
          Graham
          • grahamw01
            • 256
            That chip is Winbond 25032BVSIG, my friend at work said he would need to know the exact method to flash a BIOS to it
            Graham
            • sorinac
              • Jul 2013
              • 123
              • Romania
              your chip is W25Q32BVSIG and the .206 is the bios software u need but ask your friend what type of programing tool he has and if that tool supports spi programing .
              i am using a willem programer for this type of chips from https://www.sivava.com
              the chip must be taken off from board and attached to the programing tool on 25cxx , start the software ,select the chip type you have, open the bios file in programing software, erase the chip and then write new software.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                SPI flashes can also be written with a simple parallel port adapter, if you have a computer around that still has that port.
                A working TV? How boring!
                • grahamw01
                  • 256
                  Thanks for all your help, my friend said he hasn't got anything that can program SPI chips, I guess there is not much I can do then.
                  • sorinac
                    • Jul 2013
                    • 123
                    • Romania
                    get your notebook to a repair shop and give him the bios file to write it to chip
                    • grahamw01
                      • 256
                      I was hoping for an cheaper solution. I found someone selling an N55SL BIOS chip in America, maybe this will work..
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        If you ask them nicely, they will do it for cheap. I got one done for free.
                        • dj_ricoh
                          • 2073
                          do you got the chip out? or you need to desolder it to?
                          • grahamw01
                            • 256
                            It is still soldered in but I can easily get it off and replace it.
                            • grahamw01
                              • 256
                              Before I order a new chip can someone please just confirm this is definitely the problem? As I said in the first post, I find it strange that it is absolutely dead, it will not even show a charging light when the AC is plugged in, no lights no sounds no fan.. could not be more dead!
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                There is main BIOS and EC BIOS. Some laptops have them in separate chips, on others it's in the same chip.
                                The EC controls all the buttons and LEDs and whatnot, so if the EC BIOS is corrupted, the laptop will be completely dead, yes.
                                • grahamw01
                                  • 256
                                  thanks everyone, someone will be looking at flashing the chip for me
                                  Graham
                                  • grahamw01
                                    • 256
                                    good luck.
                                    Hi again,
                                    Just an update - I sent the BIOS chip to a very kind person who flashed it for me using the file you uploaded (N55SLF1204.zip), I go the chip back and amazingly the laptop now did turn on, unfortunately the laptop did not do much else. The fan instantly spun on full speed and nothing was displayed on the screen, after a while the laptop turned off. After several attempts turning it on it slipped back in to absolutely dead mode, no lights, not even charging etc.
                                    I checked the ASUS website and the BIOS file they have available is "N55SLAS204.zip" for the N55SL, which is not the same you gave me. Is the one you uploaded for a different machine/motherboard?
                                    The chip has been removed again and sent again to be flashed with N55SLAS204, I will receive it back sometime next week. I just wanted to know now if flashing with the file you suggested caused the further problems, or if it should work but there is something else wrong..
                                    Regards
                                    Graham
                                    • sorinac
                                      • Jul 2013
                                      • 123
                                      • Romania
                                      unfortunately the bios file is not exactly for your motherboard and I don't have other bios file available , but i will still search a full dump for you.
                                      the file from asus website is only ~2.6mb and is only an update to your bios. it will not work.
                                      You need the full 4mb file.
                                      Please post some details of your laptop : full model from back , cpu type , video (onboard,dedicated and type (nvidia,ati)) , chipset model , the exact name from mainboard.
                                      • grahamw01
                                        • 256
                                        Thank you, the sticker on the back says
                                        MODEL: N55S
                                        MB Ver: N55SL ID:1C
                                        N55SL-S2019V
                                        Both CPU and GPU are changeable, the GPU is on a separate card, but my current processor is Core i7-2670QM and GPU is nVidia GeForce GT 635M w/ 2GB dedicated RAM.
                                        I do not have the motherboard, I left it at work, but I could not see a MFN number on it. all it said was N55SF Rev 2.0.
                                        I checked N55SF, it is the same laptop but different CPU/GPU. N55SF and N55SL share identical motherboard, which is just called N55SF Rev 2.0.
                                        Hope this helps!
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • what_1282105
                                          Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                          by what_1282105
                                          Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                          02-14-2025, 07:27 PM
                                        • tranquility
                                          Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
                                          by tranquility
                                          hallo,
                                          i have an asus X515KA-EJ058W here.
                                          just both leds white...he battery blinking without battery connected
                                          consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
                                          if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
                                          power on again is possible but again 400mA then and no picture.
                                          now the really strange
                                          i flashed bios (some version i found on the internet) and resoldered....sometimes...
                                          12-11-2024, 06:47 AM
