Lenovo Golden Key V3.5.60 - DMI EDITOR (BOOTABLE USB)
  • rowerius
    • May 2025
    • Czech republic
    #41
    Hey Guys, I need help. Everytime I try to update, this window pops up.
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1316
      • France
      #42
      version 3.5.75 but which is actually the 3.5.76
      downloadable here
      03-05-0076
      https://seservice.lenovo.com/static_...-0076/uone.rar
      With hash SHA-1 | 160-bit : eab2f41ced1f0bd1f8d489253f1ae571da582026
      Previous version of 03-05-0075
      https://seservice.lenovo.com/static_...-0075/uone.rar
      With hash d060859f579d8473b3215ea8332fbec83926e6ca
      The downloadable archives are password protected, I don't yet have a solution to open them directly.
      I use the U1 application to extract the files.
      To download the latest version without having to do all the updates, modify the file " v_query.txt " directly or replace with my file
      Same method as here, just copy new update
      https://www.badcaps.net/forum/troubl...17#post3542717
      For this problem,not solution for the moment
      Not tested, just download
      please give feedback​
      • Cedriccc
        • May 2025
        • Fr
        #43
        The password is 4420MB2gku1
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1316
          • France
          #44
          Click image for larger version  Name:	image.png Views:	0 Size:	61.4 KB ID:	3641412
          I tried with the P and the - too. I suspected that it was there
          • SoporteNetFe
            • Aug 2021
            • 121
            • Argentina
            #45
            I think some functions no longer work because the tool has already been replaced.
            The program download the hash of Lenovo Diagnostics ISO, but not the file.
            • wetobias
              • Jun 2025
              • Sweden
              #46
              anyone got the new tool?
              • Markus1741
                • Sep 2020
                • 907
                • N/A
                #47
                Lenovo T14 Gen2
                Serial Number: PF2VNWNH
                Board Number: NM-D351
                Hello a strange behavior by Lenovo Golden Key U1.
                I could easily write the missing data with the tool, but after each restart, the error message 2200 and 2203 appear although all data appear correctly in the BIOS.
                I tried a lot of deleting EEPROM and reentering the data but always errors 2200 and 2203.
                After pressing ESC, the notebook loads as normal very funny behavior.
                Lenovo Tool is U1 Version 3.5.75
                • denyslykh
                  • Jul 2022
                  • 4
                  • Ukraine
                  #48
                  Dear All, good day!
                  All working,
                  Frist : format usb stick to FAT32 UEFI throw cmd command, you can find at Google search - how to make it.
                  Second : After USB formated make update the programm up to last version. Programm will create files on USB stick. Were comleted updates - usb stick is ready. Just what to need reboot throw F12 bootloader and choose USB stick.
                  Enjoy.
                  • Arumus
                    • Aug 2025
                    • Россия
                    #49
                    Hello, I tried to update the Product Name, but I always get an error, I write Ideapad Gaming 3 15IMH05, it only resolves if everything is continuous, there is a way to do it without (-) instead of a space.
                      • 21615
                      If you have your original bios backup the DMI can be copied to the new bios, if it`s not corrupted . Offsets 532000 - 533FFF
                      • Arumus
                        • Aug 2025
                        • Россия
                        #51
                        They just broke my laptop in the service as best they could, all that there is is a program for rewriting, the name of the laptop is everything, I entered the serial number, the rest too, just the name, and they redid the bios for me there a long time ago, I bought myself the old version to change the serial number, then I'll try to put a new bios, maybe it will help
                        • Eighttech
                          • Aug 2025
                          • Ireland
                          #52
                          Guys I Have a Gen 11 X1 Carbon 2023 model I think....the new motherboard from lenovo arrived....I can't seem to set the B0 or C0 ...I managed to set the Mac Lan, I'm trying to.copy the old details from.the old board.
                          • shybear
                            • Jan 2010
                            • 105
                            #53
                            As Maxpower3 explained clearly on post #43 all worksa fine. I share some some tips to considered so the process will be end successufully.
                            - use the format USB tool provided on post #43, no matter to choose FAT 16 or FAT 32 and don't worry if at the end of process it will say that EFI information are missed.
                            - copy the 3.56.75 into the root of USB inside this archive there is also the EFI folder.
                            - extract U1 Key updater.zip of post #1 and overwirte the v_query.txt with the one of post #43
                            - next (keeping usb attached) run U1.exe press Update to update the tool on usb key to last version. (actually 3.56.78)
                            To use it on laptop that requires MDM infoe follow this suggestions.
                            - first of all I suggest to update BIOS via software no matter if it will be the same version you have programmed on chip.
                            This is usefull expecailly when U1 Tool show an ERROR 53 TRIGGER while writing DMD infos and doesn't works.
                            - I suggest to remove hard disk so the laptop will ask you to choose or insert a bootable media
                            - as you can read on the first screen use the command SUone.nsh so it will asks all MDM infos and next it will write on BIOS
                            - I M P O R T A N T along the writing process it will looop several times and its possibile that some infos shows "not found" at first. Let it loop and don't interrupt process and wait that the program will wrtie all fields.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1316
                              • France
                              #54
                              Name 3.56.78 but which is actually 79
                              • SoporteNetFe
                                • Aug 2021
                                • 121
                                • Argentina
                                #55
                                Anyone have LSTC? Need autorized login to download like U1 Update:
                                https://download.lenovo.com/auth/dfs/LSTC/LSTC.zip
                                https://download.lenovo.com/auth/dfs/U1/u1u.zip
                                • bub2
                                  • Dec 2016
                                  Maxpower3 I follow your work with admiration. Could you please share the program in the photo? I need to read and write dumps.
                                  Thanks.
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1316
                                    • France
                                    #57
                                    Thanks.
                                    I abandoned this version, I don't know where it is anymore.
                                    • 99akaila
                                      • Sep 2025
                                      • 3
                                      • pakistan
                                      #58
                                      Thanks Hypermark...it worked smoothly...originally it came with v3.5.40 but after few updates it is .60....i was able to update my Lenovo ideapad V14 G3 IAP using uoneS command and entering correct mtm and serial number...it automatically picked up model name
                                      • 99akaila
                                        • Sep 2025
                                        • 3
                                        • pakistan
                                        #59
                                        i used uoneS command, entered serial and mtm and it picked up model name automatically with gaps...just write uones hit enter than add serial and mtm number
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
