Is there a solution to the HP 440 G7 EndPoint Security Controller Problem?
Hi guys,
I'm having a Probook 440 G7 with the infamous "endpoint security controller" message. Hope somebody can help. Flashing a clean BIOS alone does not help, the message remains so apparantly it needs to be patched like some other models.
Details:
Probook 440 G7
Mobo model: DA0X8MMB6D0 rev: D
Serial number: 5CD034LDWB
The orignal dumps are attachted.
Thanks!Attached Filesif you find these attachements useful please consider making a small donation to the site
XXXHi guys,
Details:
Probook 440 G7
https://www.badcaps.net/donateComment
Thanks Hoaca! Just flashed it, but unfortunately the annoying message remains
I tested twice just to be sure. Also programmed back the DMI data if that would make any difference but it did not. Do you have another clue?
AgainAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi guys,
Details:
Probook 440 G7
Serial number: 5CD043C3VJ
Thanks!
# 5Hi guys,
Details:
Probook 440 G7
Thanks!
Attached Files↵
by kolebbkHi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
HP Endpoint Security Controller problem
there is a problem with the hp endpoint security controller on the unit
I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...-
by fede77Notebook HP ProBook 450 G8
ProdID 2K8L1LT#AC8
Mother: DAX8QAMB8D0 REV D
The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....03-10-2025, 07:12 AM -
by lamondeHi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
and there is no soud after flashing new bios, may be have some solutions?
ProdID: 4YD62AV
SN: 2TK9500V8X...-
Channel: BIOS Requests ONLY!
by biednybelferAfter removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
Mainbard model:6050A3044201-MB-A01 (A1)
Serial Number: 5CG0275ZLV
(I'm not allowed to upload files with the extension bin, so I upload zip)...-
by Voyager65Hi all,
I got a used HP and see this well known HP Endpoint Security Problem Screen. Someone seems to have removed the password and reflashed the bios with (maybe) a wrong serial etc.. I was able to read and write with my programmer a new bios onto it - same problem. I tried a downgrade, same.
I did password removal wir rcunlocker on several other machines without any problem. But this one is/was killed before. Appreciate any help.
SN: 8CC1120Z0V
PN: 8WY18AV
Bios Dump:
Thanks a lot...-
- Loading...
