HP 800 G6 Deskop Mini - Endpoint Security Controller Problem
  • Voyager65
    • Jul 2023
    • 6
    I got a used HP and see this well known HP Endpoint Security Problem Screen. Someone seems to have removed the password and reflashed the bios with (maybe) a wrong serial etc.. I was able to read and write with my programmer a new bios onto it - same problem. I tried a downgrade, same.
    I did password removal wir rcunlocker on several other machines without any problem. But this one is/was killed before. Appreciate any help.
    SN: 8CC1120Z0V
    PN: 8WY18AV
    Bios Dump:
    Thanks a lot
  • hoaca388
    Badcaps
    • Jan 2022
    • 12347
    Upload bios file .
    • Voyager65
      • Jul 2023
      • 6
      Thanks hoaca388,
      a) Bios which was on the maschine
      b) Bios I used rcunlocker on it.
      Both with the same error.
      Thanks for your help
      • hoaca388
        Badcaps
        • Jan 2022
        • 12347
        Originally posted by Voyager65
        Thanks hoaca388,
        This is EC files, upload a bios file, it from another chip.
        • Voyager65
          • Jul 2023
          • 6
          I tried to read the 32MB Chip with HP Software, but I'm not sure if this can be used by you. If you know a good way to dump the HP Bios by software, please let me know or point me to a source where I can read about it.
          I just ordered a soic16 clip in case, that this file is not useful for you. With this, I can use my programmer to dump the bios ic.
          Attached what I did with the HP tool
          • hoaca388
            Badcaps
            • Jan 2022
            • 12347
            What the hell are you doing?
            • Voyager65
              • Jul 2023
              • 6
              Now I got the Bios dumped:
              • hoaca388
                Badcaps
                • Jan 2022
                • 12347
                HP EliteDesk 800 G6 Desktop Mini PC IDS Base Model
                • Voyager65
                  • Jul 2023
                  • 6
                  Thank you very much. It worked great. I was able to put my information with the HP BIOS Configuration Tool into the BIOS.
                  But I can‘t set "Born date" and "UUID". Is there any way to do this? Would be great to have my old system back 1:1.
                  I have all the data from the old state saved via the configuration tool as text file.
                  • mrrubik
                    • Dec 2024
                    • 13
                    I got a HP EliteDesk 800 G6 DM with a locked admin password, I attempted this method to reset https://blog.rhysgoodwin.com/it/hp-e...sword-removal/ which was successful even though the guide had Gigadevice chip and my EC chip was Winbond (I did verify the pinouts were same).
                    However after password is reset, I'm now getting a "HP EndPoint Security Controller Problem" screen every boot, similar to this guide: https://www.indiafix.in/p/how-to-res...-security.html, I'm currently able to set a 15 sec auto-bypass in BIOS and the machine works perfectly otherwise.
                    Not sure what I did wrong as the main BIOS was not touched/updated by me at all.
                    Info:
                    SN: MXL1263M92
                    PN: 20H61UT#ABA
                    Main 32MB bios dump is attached, thank you so much BadCaps!​
                    • Bios Cracker
                      • Oct 2024
                      • 322
                      • India
                      Info:
                      SN: MXL1263M92
                      PN: 20H61UT#ABA
                      Try and Update.
                      • mrrubik
                        • Dec 2024
                        • 13
                        Originally posted by Bios Cracker
                        Try and Update.
                        Hi, I downloaded the file attached and ran a quick diff in HxD with my original read1.zip - the files appear identical? Also ran a SHA-1 hash and both files give same result Bios Cracker can you confirm, thank you!
                        • Bios Cracker
                          • Oct 2024
                          • 322
                          • India
                          My Mistake. Try This.
                          • mrrubik
                            • Dec 2024
                            • 13
                            Wonderful! Worked like a charm Thank you so much!
                            • Bios Cracker
                              • Oct 2024
                              • 322
                              • India
                              Enjoy Mate.
                              • chrisyau
                                • Aug 2025
                                • Hong Kong
                                Hi
                                I got same issue that my HP EliteDesk 800 G6 mini report Endpoint Security Controller problem", I have download the .bin file from above but don't know how to refresh th BIOS using downloaded .bin file, please help, thanks
                                • khanlala
                                  • Aug 2019
                                  • 6
                                  • pakistan
                                  remove security endpoint error from 800 G6
                                  S/N . MXL2055KX0
                                  • kolebbk
                                    HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                                    by kolebbk
                                    Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                                    HP Endpoint Security Controller problem
                                    there is a problem with the hp endpoint security controller on the unit
                                    I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                                    09-04-2024, 12:44 AM
                                  • fede77
                                    Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                                    by fede77
                                    Notebook HP ProBook 450 G8
                                    ProdID 2K8L1LT#AC8
                                    Mother: DAX8QAMB8D0 REV D
                                    The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                                    03-10-2025, 07:12 AM
                                  • lamonde
                                    850 G6 Endpoint Security Controller Problem
                                    by lamonde
                                    Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
                                    and there is no soud after flashing new bios, may be have some solutions?
                                    ProdID: 4YD62AV
                                    SN: 2TK9500V8X...
                                    01-15-2025, 09:31 AM
                                  • biednybelfer
                                    HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
                                    by biednybelfer
                                    After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
                                    Mainbard model:6050A3044201-MB-A01 (A1)​
                                    Serial Number: 5CG0275ZLV
                                    (I'm not allowed to upload files with the extension bin, so I upload zip)...
                                    10-05-2024, 05:04 AM
                                  • arif3203
                                    HP 430 G8 Security Endpoint controller Problem
                                    by arif3203
                                    HI badcaps members
                                    Please Help me,Problem Hp 430 Security endpoint Problem
                                    HP 430 G8
                                    Sn:5CD1318NT7
                                    Code: DAX8PMB18A0 REV A...
                                    05-15-2024, 11:02 PM
