HP 440 G7 EndPoint Security Controller Problem
  • startrek
    • Jun 2017
    • 32
    • turkey
    Is there a solution to the HP 440 G7 EndPoint Security Controller Problem?
  • dutchgaucho
    • 65
    • The Netherlands
    Hi guys,
    I'm having a Probook 440 G7 with the infamous "endpoint security controller" message. Hope somebody can help. Flashing a clean BIOS alone does not help, the message remains so apparantly it needs to be patched like some other models.
    Details:
    Probook 440 G7
    Mobo model: DA0X8MMB6D0 rev: D
    Serial number: 5CD034LDWB
    The orignal dumps are attachted.
    Thanks!
      SMDFlea commented
      Editing a comment
      Thread merged.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12453
    Originally posted by dutchgaucho
    Hi guys,
    Details:
    Probook 440 G7
    Thanks!
    XXX
    • dutchgaucho
      • 65
      • The Netherlands
      Thanks Hoaca! Just flashed it, but unfortunately the annoying message remains I tested twice just to be sure. Also programmed back the DMI data if that would make any difference but it did not. Do you have another clue?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12453
        Again
        • shanuka123456
          • Jun 2023
          • 14
          • srilanka
          Hi guys,
          Details:
          Probook 440 G7
          Serial number: 5CD043C3VJ
          Thanks!
          • hoaca388
            Badcaps
            • Jan 2022
            • 12453
            Originally posted by shanuka123456
            Hi guys,
            Details:
            Probook 440 G7
            Thanks!
            • kolebbk
              HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
              by kolebbk
              Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
              HP Endpoint Security Controller problem
              there is a problem with the hp endpoint security controller on the unit
              I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
              09-04-2024, 12:44 AM
            • fede77
              Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
              by fede77
              Notebook HP ProBook 450 G8
              ProdID 2K8L1LT#AC8
              Mother: DAX8QAMB8D0 REV D
              The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
              03-10-2025, 07:12 AM
            • lamonde
              850 G6 Endpoint Security Controller Problem
              by lamonde
              Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
              and there is no soud after flashing new bios, may be have some solutions?
              ProdID: 4YD62AV
              SN: 2TK9500V8X...
              01-15-2025, 09:31 AM
            • biednybelfer
              HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
              by biednybelfer
              After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
              Mainbard model:6050A3044201-MB-A01 (A1)​
              Serial Number: 5CG0275ZLV
              (I'm not allowed to upload files with the extension bin, so I upload zip)...
              10-05-2024, 05:04 AM
            • Voyager65
              HP 800 G6 Deskop Mini - Endpoint Security Controller Problem
              by Voyager65
              I got a used HP and see this well known HP Endpoint Security Problem Screen. Someone seems to have removed the password and reflashed the bios with (maybe) a wrong serial etc.. I was able to read and write with my programmer a new bios onto it - same problem. I tried a downgrade, same.
              I did password removal wir rcunlocker on several other machines without any problem. But this one is/was killed before. Appreciate any help.
              SN: 8CC1120Z0V
              PN: 8WY18AV
              Bios Dump:
              Thanks a lot...
              01-13-2024, 04:58 PM
