Hello,all of a sudden my laptop stopped working. Power on light turns white, but the cooler ain't starting and doesn't respond to any command. I've looked up for a bios version for this model, but there ain't no version available for this model. Laptop model is Asus K413FA and the bios chip is GigaDevice 25B127DSIG. I need the original bios version for this model, because on the main support website there is only an .exe version and i tried to extract it using innoextract and extractor v.2.0 with no results because the .bin file generated doesn't seem to have the same size as the extracted version. Thank you in advance.
Bios for Asus K413FA (chip 25b127dsig)
Tags: None
Post your laptop serial number and bios backup - https://www.badcaps.net/forum/troubl...before-posting
Also,if there are any barcode stickers or QR codes on the motherboard post pictures of them.
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... -
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by SMDFleaCommon SPI bios chip programming Questions and Answers
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by BiesseaHi there,
I'm a technician and a computer/retro computer lover.
I just bought a great Sabertooth motherboard (I really love the colours and the ASUS military scheme) to install a nice FX-8320 from AMD and make a gaming computer with a Geforce GTX 970.
For the first time I had problems with the system, but I solved and then correctly booting, I installed Windows 10 and then I started to overclock the system. I reached a stable configuration of 4,8GHZ with 1,475v.
Then I saved fan configuration, and other parameters, and saved to the overclock profile... - Loading...
