here is the attached bin file
Any one with a bios of hp 14s-dq da0pakmb6f1
❤️YOU MUST:
❤️Provide the full machine model number, serial number (or Service tag, SNID)❤️
https://www.badcaps.net/forum/showthread.php?t=103570 -
DMI @ 6C3040-6C403F
KEY WINDOWS @ 6E5000-6E502FAttached FilesComment
please help, no display
HP 14S-DQ3109TU
SN#5CD312P2C8
DA0PAKMB6F1 REV.F
thank you very much in advanceAttached FilesComment
Try and feedback tksOriginally posted by thixplease help, no display
HP 14S-DQ3109TU
SN#5CD312P2C8
DA0PAKMB6F1 REV.F
ThANKS men!Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Serial number matches on HP website, HP mixed 2 different BIOS for the "same" model, one is F.36 (F.36 is for the 14-dq2xxx), the right BIOS for the 14s-dq3xxx is F.70, you have to select Win11 24H2 as the OS to get the correct BIOS
HP Laptop 14s-dq3005np (7X924EA)
Bios ver F.70
BID 88E9
DMI: 6C3000h-6C403Fh
WIN key + MPMLock: 6E5000h-6E600Fh
Attached clean BIOS extracted from HP website, with your serial/Win key inserted, taken from post 13
Attached FilesLast edited by m1ch43lzm; 07-22-2025, 03:35 PM.Comment
Please help me, brother, with my HP 14s DQ3110TU laptop. I keep pressing the w key. I've replaced it with a new keyboard, but it's still the same. Even if I remove the keyboard, it still presses. I'm using an external keyboard, but it's still the same.
model: 14s-dq3110tu
SN: 5CD3180X3G
MOTHERBOARD: DA0PAKMB6F1 REV:F
We have attached the BIOS file below, please help check whether this BIOS has a problem.
Thanks m1ch43lzm, it worked 100%! appreciated.
Bios ver F.70
BID 88E9
Hello guy! today i got HP 14s-dq3110TU, the problem is laptop keep restarting and not even boot or displaying HP logo, hope somebody can help. Thanks in advance
Model : 14s-dq3110TU
Motherboard : DA0PAKMB6F1 REV:F / 0PAK
SN : 5CD31941GG
ProdID : 7Z6W5PA#AR6
BID : BID088E9Attached FilesComment
HP Laptop 14s-dq3110TU (7Z6W5PA)Hello guy! today i got HP 14s-dq3110TU, the problem is laptop keep restarting and not even boot or displaying HP logo, hope somebody can help. Thanks in advance
SN : 5CD31941GG
BID : BID088E9
https://www.badcaps.net/donateComment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by joshAUHi all.
I'm looking for a BIOS file for an Asus N550JK.
I have a Asus R552J, which I believe is identical to the Asus N550JK.
I downloaded the latest BIOS (210) for the R552.
It is named N550JKAS.210.
The BIOS file is however only 6mb in size.
I've read the chip with a CH341A programmer and verified the file.
That file is actually 8mb in size.
I'm wanting to remove the BIOS password from this unit.
It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
