hp 15s-fq0036nl Help Bios Please
  • albologna
    • May 2022
    • 32
    • italy
    I have this Hp with corrupted bios.
    With Me analizer it says' Error: Detected CSE Extension 0x16 with wrong Partition Hash at FTPR > FTPR.man! '
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    ❤️YOU MUST:
    ❤️Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see
    Posted bios is configured already send its original corrupted backup
    https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.❤️
    • albologna
      • May 2022
      • 32
      • italy
      Sorry.
      ProdID : 8EX59EA#ABZ
      S/N 5CD936836R
      Motheboard DA00P5MB6D0 REV
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Posted Bios Serial number :- 5CD93318RL
        DMI @ 340000-3400FF
        KEY WIN @:- A9E000-A9E02F
        • albologna
          • May 2022
          • 32
          • italy
          It has already been repaired by someone. Pn the plastic it has this serial 5CD936836R
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            That's why you should follow the RULES so the people here trying to help you they will not miss guide
            and most important you will get a good and positive result
            BTW what is the status after flash given bios ist work or no​
            • albologna
              • May 2022
              • 32
              • italy
              It stays at 014 mha consuption e no post. All voltages are present. Sorry for the inconvinient
              • qayyum786
                • Aug 2018
                • 1959
                • INDIA
                Since we don't have a original bios so we don't know your actual BID
                this 4 file extracted from EXE as per your serial number
                you may try and chk
                • FalconPunch
                  Surface Pro X 1876 Bios corrupted
                  by FalconPunch
                  Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                  Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                  08-09-2025, 03:56 AM
                • zlr8r
                  Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                  by zlr8r
                  Greetings
                  I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                  Serial Number: 5CG3202C16
                  Product #/SKU: 739P0AV
                  CT Number: PRTUE00WBI30YX
                  Description: HP ZBook Firefly 14 inch G10
                  BuildID: 23WWWGAZ602#SABU#DABU
                  Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                  MAC address not found.
                  • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                  10-28-2025, 01:56 PM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • TylerHyde21
                  Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                  by TylerHyde21
                  Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                  I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                  I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                  This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                  06-29-2024, 10:38 AM
                • Loli Popu
                  DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                  by Loli Popu
                  Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                  12-13-2024, 08:29 AM
