SAMSUNG NP300E4X - BIOS dump needed
  • kasatmata
    • Sep 2012
    • 18
    • Indonesia
    model: Scala3-14CRV rev.1.0
  • ysrtech
    • Sep 2016
    • 3
    • philippines
    Re: SAMSUNG NP300E4X - BIOS dump needed
    up... im also needed...
    • PlusCom
      • May 2013
      • 50
      • Greece
      Try this one
      • djharold
        • Aug 2015
        • 245
        • COLOMBIA
        thanks
        • sourcebf
          • Jul 2016
          • 433
          • N/A
          try this
          • jose osorio
            • Jun 2020
            • Colombia
            Originally posted by sourcebf
            try this
            Thanhs
            • JuanJSAR
              • Apr 2023
              • Colombia
              try this
              thank you so much.
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • Kjell
                Samsung Series 9 - BIOS issue
                by Kjell
                After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                08-01-2025, 09:15 AM
