INSYS GW1-W116 15Wr-Plus Bios
    • 22276
    Virgin bios,extracted from windows update.
    Bios Ver: 3BAPS06 , EM-IG218_v2.0.8 , IG218_V6
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
  • akwky
    by akwky
    Hi!
    04-14-2025, 01:56 PM
  • al3m0di
    Update bios EFCN58WW to EFCN59WW
    by al3m0di
    Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
    I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
    The BIOS version is EFCN58WW.
    When I turn on the device, it displays the message:
    "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
    The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
    I've tried
    07-29-2024, 10:32 AM
  • capoplays
    Help with BIOS update on Dell G15 5515 after chip replacement
    by capoplays
    Hey everyone,
    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
    When I check the BIOS using the F12 menu Flash...
    10-24-2025, 06:53 AM
  • 0xx
    2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
    by 0xx
    Hi folks,
    My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
    What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
    I assumed that Windows Update was interrupted due to closing...
    09-14-2025, 03:46 PM
