Danew Dbook 131 Bios
    • 21692
    Virgin bios,extracted from microsoft update.
    Ver: 3BAPS08​ IG118_V8
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
  • al3m0di
    Update bios EFCN58WW to EFCN59WW
    by al3m0di
    Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
    I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
    The BIOS version is EFCN58WW.
    When I turn on the device, it displays the message:
    "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
    The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
    I've tried
    07-29-2024, 10:32 AM
    Post your Microsoft Automatic bios Update Hardware ID`s
    by SMDFlea
    Some of the newest laptops have the capability to automatically update the bios from Microsoft update.
    If its enabled there will be Hardware ID listed in device manager under
    Firmware - System Firmware - Details - Property - Hardware ID`s - UEFI\RES_
    Example: UEFI\RES_{5E28725C-AA01-4AAA-9E44-414B5EE2EA44}
    Entering the hardware ID {without the curly brackets} at https://www.catalog.update.microsoft.com/Home.aspx
    will show a list of available updates.The downloads are cab files,they can be extracted with winrar or 7-zip.
    Each extracted cab...
    08-04-2022, 12:30 PM
  • ahmypc
    Microsoft Surface Pro 4 Bios Update Issue
    by ahmypc
    The device that has not received an update for a long time cannot update the new ME Region. That's why touch doesn't work. Bios file cannot be opened with Flash Image Tool. Additionally, I am attaching the update file downloaded to the device and the original bios file. I would be glad if you help....
    09-21-2023, 02:14 AM
  • 0xx
    2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
    by 0xx
    Hi folks,
    My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
    What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
    I assumed that Windows Update was interrupted due to closing...
    09-14-2025, 03:46 PM
