hp 17-cd0075nf bios DMI
  • madjid911
    • Dec 2016
    • 404
    • France
    the laptop started with no display, so I changed its bios with the correct BID (085FD), I tried with "CopyDMI" to to put the DMI, but the DMI didn't work, and when starting it marks " Manufacture Programming Mode Is In Unlock"
    Can you give the correct DMI so that there are no more error messages please?
    Laptop HP PAVILLION GAMING 17-cd0075nf
    SN : CND93901RN
    ProdID : 8KU04EA#ABF
  • peste
    • Dec 2016
    • 13339
    • ROMANIA
    SN : CND93901RN
    DMI + KEYWIN 300000 - 30102F
    DMI + KEYWIN 300000 - 301FFF
    • madjid911
      • Dec 2016
      • 404
      • France
      [QUOTE=peste;n3174375]
      Thank you very much, the DMI is good I was able to get all the information in the bios.
      However, I still get the error message : " Manufacture Programming Mode Is In Unlock", Do you know how to stop getting this message at startup please ?
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria πŸ‡§πŸ‡¬
        [QUOTE=madjid911;n3174391]
        Use HP BCU to exit "Manufacture Programming Mode Is In Unlock Mode"
        Become a Badcaps supporter
        Thanks to all supporters.​
        • madjid911
          • Dec 2016
          • 404
          • France
          [QUOTE=Vesko356;n3174438]
          I found this which explains how to use BCU to remove the error message, thank you very much for your help.
          https://poweradm.com/hp-manufacture-...2tFyUIJXaFZONQ
          Quick question, how do you know each time where the DMI is located please?? I would love to know the trick.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria πŸ‡§πŸ‡¬
            https://poweradm.com/hp-manufacture-programming-mode-unlock/?fbclid=IwAR1Z4rYHg03EMxqL6hBdyYlMpqwlw1W4_NrOhEiz EjP2r2tFyUIJXaFZONQ
            There's no need to search anything about how to use the program, there is a user manual link at the same page (with command line parameters and syntax).
            Click image for larger version  Name:	Screenshot 2024-01-07 at 20-47-14 HP BIOS Configuration Utility HP Client Management Solutions.png Views:	0 Size:	18.7 KB ID:	3174477
            Click image for larger version  Name:	Screenshot 2024-01-07 at 20-48-59 BIOS_Configuration_Utility_User_Guide.pdf.png Views:	0 Size:	53.1 KB ID:	3174478
            About the DMI location, there's a different approach for every make and model, for example in your case searching for the serial number with the hex editor points the DMI area easily.
            • madjid911
              • Dec 2016
              • 404
              • France
              I understand, thank you very much for all the details. Is there a page on this forum that gives all the approaches to finding the DMI for all brands of laptop? I haven't found one, it would be very interesting to have one.
              Last edited by Vesko356; 01-07-2024, 05:05 PM. Reason: Removed full qoute with images
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria πŸ‡§πŸ‡¬
                BIOS guides, methods, resources and tools ---> 4. DMI editing by brand​
                  by SMDFlea
                  Bad...
                  09-02-2021, 04:40 PM
                • macabook
                  πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
