BIOS Request for HP Pavilion 15-bc009nm
  • Hombre
    • Jul 2013
    • 231
    • Croatia
    Model number: 15-bc009nm
    Serial number: 5CD64518KV
    Motherboard: DAG35AMB8E0 Rev:E
    Laptop had dead SR2C4 chipset, replaced it and now the charger is working and on start both fans start to spin, caps lock blinking 5x long and 3x fast, screen is black.
    U5 that was installed was 25Q16 and according to schematics it should be 25Q64, but i am not sure how that happened, i am not the first one diving into it.
    Tried some bins for some similar models but it did not work out, and for this specific model could not find any dump.
    I tried to etxract the bios from HP site, but was not able to do it ;(
    I tried to make an dump from EC - not sure if it is ok, but it should be, you can find it attached.
    I assume it's BIOS issue, cut could be hardware also, although i have all necessary voltages.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12397
      • 22084
      15-bc009nm product spec - https://support.hp.com/gb-en/document/c05232416 . i5-6300HQ Skylake H .
      SKYLAKE H ,BID0820D ,BID0825F ,BID08294 - https://www.badcaps.net/forum/troubl...0-rev-d-e-bios
      Your BID must be 0820D as Hoaca extractd those 3 bios from the HP bios update .
      • Hombre
        • Jul 2013
        • 231
        • Croatia
        Thanks, tried it in combination with the 0820D EC that you posted on another thread and it behaves the same, no video, fans spinning, and caps lock blinks 5x long 3x short.
        And this 0820D in combination with my EC backup starts the fans, no video but no blinking from caps lock.
        something is missing/wrong from hardware side possibly - maybe i should try to reflow chipset.
          • 22084
          Check the ram slot pins carefully for any loose ones and resolder them.
          • Bloodhoundje
            by Bloodhoundje
            03-16-2024, 03:12 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • sssssssssssssss
            Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
            by sssssssssssssss
            I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
            Symptoms:
            • Laptop powers on but no display at all (completely black screen)
            • Caps Lock blinks twice with a pause, then repeats continuously
            • F12 LED stays on permanently
            • No POST, no boot sequence, nothing on screen
            Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
            What I've tried:
            • Hardware reset (battery removal, power
            09-04-2025, 06:45 AM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
            by Vesko356
            08-11-2023, 03:27 AM
