I tried using Configurator. When I try to do anything it just reboots to recovery with no option for terminal. I'm not sure if it is also icloud locked however I do not think so. Do I have any options?
Macbook Air m1 2020, MDM locked, boots to recovery, reboots to recovery upon restore
by 1centchipsGoes to recovery when plugged in with another Mac, shows in finder with a question mark and serial number. When revived fails at error 9 (the laptop turns off and on?) In the Apple Configurator when in dfu, gives error restores device removed before restore completed 0xFAA (4010). Tried in intel and m1 based Macs.
History, came in with severe liquid damage and bubbly motherboard
Transplanted t2/ recalled ram, u4730, all 4 nands and u4770.
Below is the log from console, the usb meter negotiates at 19v and goes as high as 2.4A
Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]:...04-01-2026, 11:38 AM -
by anik0101010Hi everyone,
I'm working on a bricked RCF M18 digital mixer. The unit was completely dead, but I managed to resurrect the hardware doing a low-level recovery via the internal UART header and the Debug Jumper method (as per RCF Service Note 1903B).
I successfully booted from the SD card, wiped the NAND, and flashed U-Boot. The CPU is alive and I now have a working serial console at the RCF-M18# prompt.
The Problem:
The recovery script halted because the official firmware update provided by RCF on their website (.mpk format, ~1.5MB) is just an application...-
by clrscrHP BIOS on AI-Generation Platforms: MPM Unlock and DMI Reprogramming Challenges
On recent HP platforms commonly referred to as AI-generation systems, unlocking MPM (Manufacturing Programming Mode) in order to reprogram DMI information has become significantly more difficult compared to earlier generations.
The level of firmware security has been raised substantially, and solutions that were previously effective on older platforms (for example, G11 and earlier generations) are no longer applicable or reliable on these newer systems.
1. Increased Firmware Security Archi...-
Channel: BIOS Requests ONLY!
12-24-2025, 09:56 AM -
by kitorHello,
I have Dell Latitude 5280, device blinks BIOS recovery error. If booted with proper pendrive, boots into recovery but asks for admin password.
Serial is GCDFLH2, since I don't get usual prompt I don't know the "suffix". From dump I assume it is -2A7B. However using password from generator on recovery prompt doesn't seem to work for me (using ctrl+enter for input).
I attached the image, UEFItool definitely complains about checksum issues. Maybe someone is able to fix the image or at least remove the password?...-
by iamdiracHello everyone,
I have a Lenovo Yoga Slim 6 14IRP8 that got stuck in a BIOS recovery loop after a BIOS update was interrupted through Lenovo Vantage.
Here are my device details:
- **Model:** Yoga Slim 6 14IRP8
- **Serial Number:** YX07A9YJ
- **OS:** Windows 11 64-bit
**Problem:**
Every time I boot, I get the message: "Do you want to recovery ROM part? (Caution: Not every OS is bootable in Recovery Mode.)" with two options: YES or NO. The screen just stays there with both options and does not do anything on its own. When I...-
- Loading...
