Dell 5280, broken BIOS (boots only into bios recovery) with password.
  • kitor
    • Apr 2019
    • 47
    • Poland
    I have Dell Latitude 5280, device blinks BIOS recovery error. If booted with proper pendrive, boots into recovery but asks for admin password.
    Serial is GCDFLH2, since I don't get usual prompt I don't know the "suffix". From dump I assume it is -2A7B. However using password from generator on recovery prompt doesn't seem to work for me (using ctrl+enter for input).
    I attached the image, UEFItool definitely complains about checksum issues. Maybe someone is able to fix the image or at least remove the password?
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dell 5280, broken BIOS (boots only into bios recovery) with password.
    Become a Badcaps supporter
    Thanks to all supporters.
    • kitor
      • Apr 2019
      • 47
      • Poland
      Thank you, indeed this one boots and it is clean (no password).
      Though it also lost all machine details - service tag (that I was able to program at first boot) and, from what I can tell - embedded windows licence key.
      Is it possible to just fix the checksums somehow, without password removal? If I understand correctly then it should boot successfully in regular mode and I could use master password generator as usual.
      Or maybe I am wrong, as I see SLIC table, but in original dump there was key too (starting with RNB4J). Maybe this is enough, as Win10 activated online without any issues?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12330
        Try this file
        • kitor
          • Apr 2019
          • 47
          • Poland
          Originally posted by hoaca388
          Try this file
          Thank you!
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • sssssssssssssss
            Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
            by sssssssssssssss
            I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
            Symptoms:
            • Laptop powers on but no display at all (completely black screen)
            • Caps Lock blinks twice with a pause, then repeats continuously
            • F12 LED stays on permanently
            • No POST, no boot sequence, nothing on screen
            Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
            What I've tried:
            • Hardware reset (battery removal, power
            09-04-2025, 06:45 AM
          • BlueNitesFire
            I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
            by BlueNitesFire
            So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
            03-08-2025, 03:49 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • The_Memory_Guy
            Dell T7820 stuck in Bios Recovery Mode
            by The_Memory_Guy
            HI,
            I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
            What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
            All of them say to download the latest bios from the dell website which is a .exe file. I have done that
            https://www.dell.com/support/product...BUT090/drivers
            Some...
            07-07-2025, 06:52 AM
