NB3029_MB_U_V4 - start with no picture. I am attaching the bios dump.
					IdeaPad 5 Pro 16ach6 bios
 https://www.badcaps.net/donateComment
 3.3 v next to the EDP switch is there, but no one controls it. I will look at the diagram again.
 I have also tried with a monitor on the HDMI port - no picture.I do not rule out the possibility of damaged memory that is soldered to the mainboard.
 Num Lock and Caps Lock are also unresponsive, for this I went to bios or ec dump IT8987ELast edited by didoee; 12-28-2023, 05:27 AM.Comment
	Comment-
 Start a new thread in the main laptop troubleshooting forum for help, its not a bios issue at the moment -> https://www.badcaps.net/forum/troubl...mobile-devices
 Hello Badcaps People,
 This is my first time posting here, but I've understood this is the best place when looking for expert assistance! Thanks for having me.
 My problem is the following: My laptop (used to... see below) works good, except that the bios/UEFI settings are locked behind an "System Password". This is strange, since I've bought it new and can't recall setting the password. I've contacted the seller, no luck. I've contacted Lenovo, they can't/don't help. I've also tried other methods, with no luck. A repair shop has tried to update the bios to solve this problem, but no luck. They concluded that the only option is to read the bios chip and flash a corrected version. I'm new to this, but have given it a go.
 I have used a ch341a programmer to read my bios chip of my laptop. After several attempts, I finally got the software (NeoProgrammer) on a different laptop to recognize the chip. I then read the bios and got a .bin file that was not only F's (not empty). I did not erase anything or write something new to the chip. I disconnected the programmer and reassembled the laptop. However, when I try to restart my laptop, I only get a black screen. The keyboard lights up initially (as normal) and the fans start spinning at a constant rate being relatively loud (not usual). The screen powers on, i.e., becoming less black than turned off, but stays completely black afterwards. It remains in this state even after waiting for a while (10-15+ minutes).
 I therefore have 2 questions:- How can I repair my laptop? (I don't understand how, if nothing was changed in the bios chip, the laptop suddenly does not turn on)
- Can the bios .bin file (see attached file) be corrected so it doesn't have a password? And will flashing this version solve the issue?
 PS. Online someone send me a bios .bin file for the Lenovo IdeaPad 5 Pro 16IHU6. I think this uses a different motherboard, so therefore thought it wasn't wise to try and flash this. Is this true or can it be used to try and recover my device? These files are also attached, if it helps.
 === More Context ===
 Note: The NeoProgrammer also mentioned possibly needing an Adapter:
 Current programmer: CH341 Black
 SPI ID: EF6018
 Currently selected: W25Q128FW [1.8V] 128 Mbits, 16 Mbytes
 !! Adapter required !!
 22:49:29
 Reading memory... Main Memory
 Success
 Execution time: 00:02:35.147
 CRC32 = 0xA28C2C5B
 === Additional Info ===
 Laptop name: Lenovo IdeaPad 5 Pro 16ACH6 (note: not 16
 Product number: 82L5008DMH
 Serial number: YX02LE6H
 Bios version: GSCN40WW
 Processor: AMD Ryzen 7 5800H with Radeon Graphics
 Storage: 952.6 GB
 Installed RAM: 16 GB (13.9 GB usable)
 Device ID: C1F20516-6BFC-40D1-B178-0AF177348910
 Product ID: 00325-82190-15303-AAOEM
 Bios chip name: Winbond 74W12JWSIQ 2025
 I've tried to be as complete as possible in this post, hopefully someone is able to assist me. Please let me know if more information is needed. I'm really stuck without my laptop and lack the experience and expertise to do anything about it.
 Kind regards.Comment
 Your password wasI have used a ch341a programmer to read my bios chip of my laptop. ....
 L - LimaCode:lol
 O - Oscar
 L- Lima
 (I'm serious)
 Maybe someone set that password as a prank without you knowing...
 1. Most likely you damaged the BIOS chip by supplying 3.3V to it (hopefully nothing else on the motherboard including CPU), you used a CH341A which is for 3.3V chips, your BIOS chip is W74W12JWSIQ, which is 1.8V, you have to use additional 1.8V adapter with the CH341A for this BIOS chip, as the BIOS chip is connected straight to the CPU on AMD platform
 2. Your backup looks good, I will provide a new BIOS with the (encrypted) DMI data (including serial/model name/MTM and Win key) copied from your existing BIOS anyway, it will have no password (if laptop works, you have to deal with BitLocker next), the BIOS chip may need to be replaced if you connected the CH341A without using 1.8V adapter
 ideapad 5 Pro-16ACH6 Laptop - Type 82L5
 BIOS ver. GSCN40WW
 S/N YX02LE6H
 MTM 82L5008DMH
 That "someone" sent you a BIOS for Intel CPU laptop, yours is AMD, that's the first red flag 🚩PS. Online someone send me a bios .bin file for the Lenovo IdeaPad 5 Pro 16IHU6. I think this uses a different motherboard, so therefore thought it wasn't wise to try and flash this. Is this true or can it be used to try and recover my device? These files are also attached, if it helps.Attached FilesLast edited by m1ch43lzm; 10-28-2025, 02:45 PM.Comment
			This specification for the Lenovo IdeaPad IdeaPad 5 Pro 16ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 Pro 16ACH6 boardview and IdeaPad 5 Pro 16ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 04:30 AM
			by mkdjDear all,
 I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
 Here the steps I have taken to fix the laptop:
 - downloaded latest BIOS from Lenovo Website...
			by macabookHello everyone,
 🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			This specification for the Lenovo IdeaPad 5 Pro 16ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 Pro 16ACH6 boardview and 5 Pro 16ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 04:30 AM
- Loading...
