Lenovo T14 gen 1: 2203: System configuration is invalid
  • x16
    • May 2015
    • 85
    I get "System configuration is invalid" on every boot.
    I updated Bios and EC, even updated mec with svod4 with dump from lenovo and afterwards initialized eeprom with U1 and entered new serial. All DMI data are correct in Bios. But still message on every boot.
    Any ideas?
    Here the dumps:
  • qayyum786
    • Aug 2018
    • 1955
    • INDIA
    POST SERIAL NUMBER/SERVICE TAG:-
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1261
      • France
      x16 check your information it matches
      ThinkPad T14 Gen 1
      SB20X89439L1HF13Y092V
      S20S1S4QD00PF2LJEYM
      ProductIdentify.efi
      2200 machine type and serial invalid
      2202 product name is invalid
      2203 system configuration is invalid ?? (I don't know what it corresponds to exactly)
      2204 system configuration data is invalid
      can you provide your original EC dump?
      Edit:
      line 240 and 350 is full FF, this is not normal I think
      • x16
        • May 2015
        • 85
        Unfortunately I don't have an original 256kb fulldump of EC, because all dumps with 256kb are empty. I tried 20 times, but only got dump with 00. Only the 2kb dump from eeprom worked. Original file is here.
        And yes i deleted line 300 till 350 because this is the area where password ist stored. Isn't it?
        I even tried to flash back original, but same error.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1261
          • France
          have you tried a full init eeprom ?? and rewrite the information? same problem?
          can you try otherwise at the uuid level: delete and recreate another
          can you post picture of setup information (serial number and other)
          for password unlock just delete 300 to 34F, do not touch after 350​
          test mod 0x350 if possible
          • x16
            • May 2015
            • 85
            OK i think i destroyed the board. I took your 2kb file and wrote it as main 256KB. After that the board don't power on. OK my fault, but no problem, just rewrite 256 with new lenovo File. But no write possible anymore. Even erasing is not possible.
            When i press erase, it says ok, but on blank check it says error.
            Maybee my Svod4 has a problem?
            • Maxpower3
              Maxpower3 commented
              Editing a comment
              damn, your story is very strange.
          • x16
            • May 2015
            • 85
            Yes sorry for that. Sometimes i make a stupid things.
            On SVOD4 it seems that if you send a wrong file to wrong area of MEC, then it destroys the mec?
            I have no luck, but thank you very much for your help!!!
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1261
              • France
              When you are looking for nothing
              15 minutes to understand why I have a 2203 which appears on t14s gen1 with broken LCD.
              And actually when I unplug the screen, 2203 appears for use screen lol
              Sometimes I'm stupid lol
              I did tests on a working PC and each time 2203 appears if the screen is unplugged​
              • coasterghost
                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                by coasterghost
                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                System Hardware:
                Processor: AMD Ryzen 7 PRO 5850U
                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                09-08-2025, 10:46 PM
              • NostromoKane
                INVALID entries in BIOS of Lenovo Yoga C630-13Q50 Windows on Snapdragon 2in1
                by NostromoKane
                I have a Lenovo Yoga C630-13Q50 Windows on Snapdragon laptop that I bought used here in Japan. They only sell the 4GB RAM version here in Japan so I decided to purchase an 8GB motherboard off of Aliexpress. The motherboard works without issue but Product ID, MTM, and Lenovo SN entries in the BIOS are INVALID.
                I would like to input the values from the old motherboard. After searching the internet I learned about LVAR and have tried to use it to input the values but I get the following error.
                I have tried placing the LVAR folder on C drive and Desktop...
                05-08-2025, 05:48 PM
              • Yacine007
                Lenovo ideapad 3 14IIL05 invalid serial number and system model
                by Yacine007
                Hello everyone i have lenovo ideapad 3 14IIL05 BIOS showing invalid product name and MTM and SN.
                can someone help me with clean bios right informations.
                Product name : ideapad 3 14IIL05
                Model name : 81WD
                SN : PF2FFSMM
                MTM : 8IWD00QBSP
                MFG DATE : 2020/12/26
                FACTORY ID : JVHFC1
                Thank you in advance...
                11-25-2024, 04:33 PM
                Lenovo 3000 Series Schematic
                Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                3000 C100 laptop with Braille keyboard
                Lenovo 3000 C
                C100, C200 - 15-inch XGA screen
                Lenovo 3000 N
                N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                N500 - 15.4 inch screen.
                Lenovo 3000 V
                V100, V200 - 12.1-inch WXGA models
                Lenovo 3000 G
                G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                10-04-2024, 06:05 AM
                Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                09-06-2024, 06:40 AM
