Lenovo Legion 7 16ithg6 NM-D721 Bios
https://www.badcaps.net/donate -
Model: Legion 7-16ITHg6 Laptop (Lenovo) - Type 82K6
SN: PF3BJ45V
Request: bios dump
Problem: Black screen
I tried already 2 bios files from this forum, The laptop is working fine but after a month or 2 it come back again with corrupted bios and I have to program the chip again. I already tried to replace the bios chip.
The last bios i tried was this one it worked for 2 months.
Maybe its wrong bios so I'm asking for advice.
Many thanks
Attached FilesComment
SN: PF3BJ45V
Request: bios dump
Many thanks
Here is the complete file + EC.Comment
SN: PF3BJ45V
Request: bios dump
Many thanks
Thank you!Comment
Hope someone can help getting new BIOS files.
Laptop won't boot only showing rainbow keyboard. I got it running a few days ago and managed to get windows re-installed but next day it again didn't boot and no luck since.
Legion 7 16ithg6
MTM: 82K6000HGE
SN: PF3B4Q0E
Attached bios backup files 16+8mb
Here`s your new bios + DMI, flash both of them. If you want to flash the EC use this one posted above https://www.badcaps.net/forum/troubl...11#post3669411
The requester has published part of the files.
We have given him a repaired file ready to use, but he doesn't know how to split it... 🤦♂️
any ideas?
thanks for efort
Lenovo Legion 7
SN: PF3BEN2K
MTM: 82K6000HGE
MN-D721 REV 2.0
I need help with my Lenovo Legion laptop BIOS. The situation is the following:- With the original 16MB BIOS dump the laptop only gives a black screen, there is no initialization.
- If I flash other BIOS versions, the laptop boots, but the NVIDIA GPU shows error 43 in Device Manager and the VRAM is detected as 0 MB.
- I already tried replacing NVRAM, cleaning ME region, and using BIOS from update files — but none of these attempts fixed the issue.
It looks like my original BIOS is corrupted, and the GPU VBIOS/NVRAM part may also be broken.
I would be very grateful if someone could help me restore a working BIOS for this Lenovo Legion.
Thanks in advance for your support!
The VBIOS is on a separate chip, look for a W25Q16JW (1.8V) flash chip near the GPU, labeled UG10, make a copy of it
BIOS from post 24 here: https://www.badcaps.net/forum/troubl...75#post3462475
with your DMI (serial/Win key) inserted
BIOS ver H1CN58WW
SN: PF3BEN2K
MTM: 82K6000HGE
DMI D2000-D3FFF (on 16MB file)
VBIOS i think I found a matching one for the RTX 3070, also attached, PCI ID 10DE:24DD Subsys 17AA:3F8AComment
Do you have good bios for this model, or can you
Rebuild my corrupt bios, keyboard light but no display.
I try many bios here but not good.
Lenovo HY764 NM-D721 Rev 2.0 bios
16ITHG6
MTM: 82K6CTO1WW
S/N: PF3EABA8
Thank you.Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by mr.DataThis Lenovo Legion 7 16ITHg6 booted Windows fine but then suddenly got a power loss on a BIOS update.
Now it keeps on Self-healing bios processing.
When this is done it reboots and the same thing starts again, looping through self-healing.
Can I fix this somehow or do I need to flash the chip with a working BIOS?...08-23-2025, 03:13 AM -
by hvries76Hi,
Legion 7 16ithg6
MTM: 82K6000HGE
SN: PF3B4Q0E
Attached bios backup files 16+8mb...-
Channel: BIOS Requests ONLY!
07-10-2025, 12:01 PM -
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
