ThinkPad T14 gen 1 eeprom marked UPTU2 in schematic
  • servis_null
    • Oct 2014
    • 82
    • Croatia
    Maybe someone have NM-C801 board on hand?
    Need dump of a eeprom marked UPTU2 in schematics, part of PCIE to USB controller..
    Regards
  • monzer-not
    • Mar 2016
    • 22
    • syria
    try this
    • servis_null
      • Oct 2014
      • 82
      • Croatia
      Originally posted by monzer-not
      try this
      Thnx, but I dont see anything relevant to my question.
      • trepachka
        • Oct 2022
        • 461
        I just posted on another board that I have a Thinkpad T14 Gen 1 with this board in it. I can get you EEPROM contents if you are willing to walk me thru the extraction process. Currently, this computer needs a rebuilt BIOS. Once I know computer works, I would be able to get you EEPROM file.
        • volinakis
          • Jan 2021
          • 2877
          • N/A
          Regards
          Hi, dump of uptu2
          • servis_null
            • Oct 2014
            • 82
            • Croatia
            Originally posted by volinakis
            Hi, dump of uptu2
            Thnx, but something is wrong.. in schematic eeprom is marked different.. Is that AMD board?
            • volinakis
              • Jan 2021
              • 2877
              • N/A
              yes, T14 gen1 AMD 20UE, see photos
              • servis_null
                • Oct 2014
                • 82
                • Croatia
                You still got that board on you?
                Do you maybe have U15 dump?
                There was missing components near U15, manage to replace them but now turns on as soon as I pluging charger and got no image..
                Maybe U15 data corupted..
                Thank you very much.
                • volinakis
                  volinakis commented
                  Editing a comment
                  sorry, I unlocked laptop and gave back to client. Post your corrupted dump and there are many members able to rebuild it.
              • servis_null
                • Oct 2014
                • 82
                • Croatia
                No worries, thnx anyway
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1375
                  • France
                  try this
                  works thanks
                  • to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                    by to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                    I have opened the laptop and identified the main BIOS chip...
                    10-24-2025, 01:35 AM
                  • 247it
                    ThinkPad E15 G4 PD Controller TPS65994AE EEPROM
                    by 247it
                    Hi, I have a ThinkPad E15 G4 I am working on for fun, the PD chip is not talking to the charger, it's stuck at 5v, I have replaced the PD chip three times now (new chips) and always the same result, I have checked for shorts, correct voltages on the PD IC etc - 5v 3v, and the 1.6v on the cc lines, even replaced the USB C port protector IC and the charging port,
                    The PD IC has a EEPROM connected directly, it's the one in the image attached, I assume the PD chip will not start without some initial commands stored in the EEPROM, the PD IC never shows in device manager, i backed up the
                    03-23-2025, 03:53 AM
                  • Maxpower3
                    Need Motherboard BoardView files and Schematic diagram ThinkPad) P15v Gen 2 (type 21A9, 21AA)
                    by Maxpower3
                    Please,
                    Need boardview and schematic P15v Gen 2 (type 21A9, 21AA)
                    available on others sites
                    "Lenovo P series laptops (ThinkPad) P15v Gen 2 (type 21A9, 21AA) Laptops (ThinkPad) (T1200 or A2000 GPU only), Motherboard BoardView files and Schematic diagram"
                    02-24-2024, 11:05 PM
                  • jordi90
                    Lenovo Thinkpad 20LT-S0KL1G bricked after writing the wrong eeprom
                    by jordi90
                    I was given a laptop with a BIOS locked by a password. I read that one way to unlock it is to read the EEPROM contents, patch them, and write them back. I was using the typical CH341A programmer and clip to do this, but because the clip is so loose, after patching the dump I accidentally placed the clip on the wrong EEPROM and now the laptop won’t boot.
                    Can I do something to fix it? I’ve attached photos.
                    10-09-2025, 01:08 PM
                  • Ikethedergon
                    Looking for ThinkPad E15 Gen 4 AMD motherboard schematic type 21ED
                    by Ikethedergon
                    I have a broken e15 gen 4 AMD I want to fix or have someone fix. Doesn't power on properly just has a power light and fan spins. MOSFET PQ17 is burned out and I want to know what spec it is but I would like to have a schematic to look at or for the shop I may send it to to look at.
                    09-10-2025, 04:06 PM
