I need bios MSI GF63 pls
  • alfie73
    • Oct 2020
    • 32
    • Philippines
    Need BIOS MSI GF63 Thin 11UD
    MS-16R61 VER.2.0
    SN K2201N0192337
      • 21451
      MS-16R61 VER.2.0
      SN K2201N0192337
      Post your bios and EC backups, even if they are corrupt.
      • alfie73
        • Oct 2020
        • 32
        • Philippines
        MS-16R61 VER.2.0
        SN K2201N0192337​
        no display this is my back up
        • alfie73
          • Oct 2020
          • 32
          • Philippines
          sorry for having double post beacause of my net so slow
          this is my back up file or can you edit my bios to disable my gpu so built in display im gonna use
          • peste
            • Dec 2016
            • 13200
            • ROMANIA
            MS-16R61 VER.2.0
            SN K2201N0192337​
            https://www.msi.com/Laptop/GF63-Thin...GF63-Thin-11UD
            • alfie73
              • Oct 2020
              • 32
              • Philippines
              #26
              can i flash it using rt809f flasher? my loptop is no display
              • peste
                • Dec 2016
                • 13200
                • ROMANIA
                #27
                yes...
                • alfie73
                  • Oct 2020
                  • 32
                  • Philippines
                  #28
                  Originally posted by peste
                  yes...
                  Still no display can you edit my bios file and disable my gpu ithing my gpu is damaged
                  • peste
                    peste commented
                    Editing a comment
                    Don't post pictures unless asked..
                • alfie73
                  • Oct 2020
                  • 32
                  • Philippines
                  #29
                  Hell still need working bios
                  • peste
                    • Dec 2016
                    • 13200
                    • ROMANIA
                    #30
                    The bios sent is the bios from the MSI website for your model...either you didn't write it correctly, or the laptop has another problem...
                    • questore
                      • Dec 2015
                      • 523
                      • csongrád
                      #31
                      Could someone give me an EC dump for this board?
                      MSI GF63 Thin 11UD
                      Board: MS-16R61 Rev 2.0
                      S/N: k2205n0038273
                      • peste
                        • Dec 2016
                        • 13200
                        • ROMANIA
                        #32
                        MSI GF63 Thin 11UD
                        S/N: k2205n0038273
                        post the name and model of the I/O chip and the EC bios if possible.
                        • questore
                          • Dec 2015
                          • 523
                          • csongrád
                          #33
                          EC: KB9548GF2 G241971 acm241014
                          EC bios cannot be read currently I'm fighting for it (original was shorted before replacement)
                          • noname2024
                            • Aug 2024
                            • 274
                            • CỎ MỸ XỊN
                            #34
                            MSI GF63 Thin 11UD
                            S/N: k2205n0038273
                            https://download.msi.com/bos_exe/nb/E16R6IMS.113.zip
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12110
                              #35
                              EC
                              • questore
                                • Dec 2015
                                • 523
                                • csongrád
                                #36
                                Originally posted by hoaca388
                                EC
                                Thank you, as soon as i can connect it i'll be back with results
                                • questore
                                  • Dec 2015
                                  • 523
                                  • csongrád
                                  #37
                                  EC
                                  No luck, I have changed EC and have 3.3v .
                                  Power consumpsion chages on power button start and have 3.3v on all KSO and KSI pins that needed but EC does not respond to the programmer at all. Thanks anyway
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • haitham sharabati
                                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                    💀 Problem:😅
                                    - Device shows “Administrator Password”...
                                    08-07-2025, 04:54 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • DynaxSC
                                    by DynaxSC
                                    11-17-2023, 10:56 AM
