HP 15-BS166nz - DMI
  • Patchman15
    • Nov 2023
    • 6
    • France
    HP 15-BS166nz - DMI
    Good evening everyone. Following a Bios update to F.72 of my HP 15-BS166nz. The bios was bricked. I created a dump with the corrupted bios, I wiped the chip then I managed to put the F.72 bios but I'm stuck for the comparison for my DMI. The laptop starts with F.72 without the DMI but all the information is missing. Can you help me please?
    SN: CND747BWG0
    PN: 2QH33EA#UUZ
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    SN: CND747BWG0
    PN: 2QH33EA#UUZ
    Windows key and DMI info is added please try and report back
      • 22119
      SN: CND747BWG0
      PN: 2QH33EA#UUZ
      Please post the motherboard model number
      • Patchman15
        • Nov 2023
        • 6
        • France
        Hello, thank you for your help. It took me a while to work on the laptop again. I reprogrammed with the file you gave me but I now have a black screen and no keyboard indicator.
        Sorry, it's a DKL50 LA-E802P
        • Vesko356
          Vesko356 commented
          Editing a comment
          You didn't program (or solder) the chip properly, Kalilinux25's dump is OK.
          Try again, erase the chip first and use verification!
      • Patchman15
        • Nov 2023
        • 6
        • France
        Thank you so much. I followed the instructions calmly. And it works ! Sorry for the wait and thank you very much !
        • Vesko356
          Vesko356 commented
          Editing a comment
          You're welcome. Well done.
          Kalilinux25 gave you the bios, you should also thank him for his time.
      • Patchman15
        • Nov 2023
        • 6
        • France
        Hello and thank you again for your work. the PC won't go in the trash thanks to you.​
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • studdy05
          Bricked HP Probook 450 G7 Bios questions
          by studdy05
          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
          Ive got...
          07-08-2025, 09:24 PM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • DavidChunco
          Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
          by DavidChunco
          Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
          - Receive help from Dell Support (it is out of warranty).
          - Disconnect machine from AC power and battery overnight.
          - BIOS recovery process
          - Connected external display via HDMI
          - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
          03-15-2025, 11:00 AM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
